P700 Battery
Honda317
31
32
Oshkosh
If plowing snow with 700-4, using a winch, headlights and a led flashing light do I need dual battery setup
hurld
hurld
129
159
No, I plow using my winch 50" front light bar, and 2 rear LED lights all on the factory battery. I have a 2014 700-4 and am still on the original battery. No problems
Sent from my SM-N960U using Tapatalk
Honda317
31
32
Oshkosh
Thank you, I am going to use a 60 inch plow. Do you find your self packing down a lot of snow with a 50 inch plow?
hurld
hurld
129
159
I have a 50" LED light bar. (Ha) My plow is 72", so no packing down snow for me
Buford
Buford
362
586
U.S.A.
The battery box can be "opened" up to fit a YTX 20 which is what Honda should have put in them. The YTX 14 is really to small / weak.
jwfirebird
jwfirebird
927
1,446
western ny
just have to charge it when you are done, the winch is going to draw more than the stator puts out, thats what matters. constant discharged state ruins batteries. i have the ctech 4.3, you can use it on cars or quads whatever and you get what you pay for in a charger the cheap ones ruin batteries too
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
I would only add a quality battery tender, so when the unit is not in use, the battery will be topped off and ready.....
Steve-O
6
19
Findlay, Ohio
I run a 60" plow, heater, radio, windshield wiper, 36" light bar. My battery tender I purchased right after getting my 700-4 would charge it up, but then once battery went low again it would not charge up stock battery. I took my unit over to a friend that works on Polaris units but owns two Honda ATV's said I should invest in a better battery plus a better tender. He said when I'm not using my unit I should always have it on a tender which will result in longer battery life like years not one or two years. No problem so far.
Reactions: alloutdoors
DAIII
DAIII
70
92
New Hampshire
I had all sorts of issues (with a new machine) under 10 miles on the odo with starting in cold temps-- keep it plugged in 'trickle charger-(waterproof one) its not a dream tp start in any climate.
I have a 11 yr old HONDA EU6500 generator on a solar trickle charger-- original battery fires right up.
Mike129
Mike129
125
240
Iowa
I bought an odyssey recently and was wondering what you had to do to "open" it up exactly?
