P1000 Best spot to tap into key on power?
Spoof0ne
42
55
New Hampshire
i am looking for the white with a black stripe wire to tap into for my winch. I located it under the fuse box but it’s held down with I think a zip tie that’s connected to the red housing (grey). I’m not sure if I should cut it or if it will pop out with a good tug.
What would be the best section should To pull back the black wrap to tap into that key on white and black wire. Trying to keep it simple and clean.
D0C17263 9FD6 4F5C B0EF D8E05CD680D2
Reactions: BWAF
Neohio
Neohio
Beast of the East
14,465
72,308
Painesville Ohio
The cleanest install will be using this plug and play option.
KEY ON POWER Harness for Honda Pioneer 1000, 700, 500, and Talon 1000.
Not super easy to install, but keeps from piercing factory wiring.
66,167
Reactions: Spoof0ne and Neohio
Neohio
Neohio
Beast of the East
14,465
72,308
Painesville Ohio
That’s cool. Does that harness come with instructions/pics when ordered? Or can that be found here in the forum somewhere?
Easiest access I had to that spot was before I installed my windshield.
Remove hood.
Stand in cab
Shove arm down the firewall
Easiest access to power port.
Although this harness came to light AFTER I installed my goodies. I installed my winch remote right next to the power port. That position was the easiest for me to attached the nuts retaining the winch remote.
Reactions: Spoof0ne
Spoof0ne
42
55
New Hampshire
Does this install by unplugging the back of the DC accessory port and replugging it into the new harness?
If so that’s a pretty tight “feel only” area. Anyone have any issues unplugging and reconnecting without having to take anything else off?
Best access point to that plug from under the hood? I didn’t check to see if going under the pioneer would be easier.
8CAC33D4 39C8 4170 A4C1 FE8CC0E235F7
Reactions: Neohio
Spoof0ne
42
55
New Hampshire
Remove hood.
Stand in cab
My bad. Should have refreshed the page before I replied
Reactions: Neohio
Remove hood.
Stand in cab
Thank you!
Reactions: Neohio
66,167
From the passanger front tire is where I access it. Removing the tire helps alot too as you can sit down and have a good line of sight.
Also. If you have a switch panel. Cutting a hole big enough for your hand and it's right there under the panel.
