Blackwater Evolution 30x10-14 specs
Spoke with ITP about the tires I planned on putting on my 1000
ATV / UTV
Tire Information
Inventory Code-6P0116
Size-30x10.00R14NHS
Tread Pattern-Blackwater Evolution
Ply Rating-8
Load Index-96
Speed Symbol-F
Dimensional Data
Mounted Diameter- 30.0 in.(762 mm)
Mounted Width-9.9 in.(251 mm)
Rim Width-8.0 in.(203 mm)
Rim Diameter-14 in.(356 mm)
Tire Weight-33.2 lbs(15.1 kg)
Tread Depth-31/32"(25 mm)
Inflation and Load Data
Rated Pressure-32 psi(221 kPa)
Rated Load-1570 lbs(712 kg)
Rated Speed-50 mph(80.5 km/h)
E71bfe3f0069b73f5112b39e0eed84d1
273,461
ATV / UTV
Tire Information
Size-30x10.00R14NHS
Ply Rating-8
Load Index-96
Speed Symbol-F
Dimensional Data
Those are some nice looking tires 8ply should be plenty tough.
Reactions: pct
Worked well on the 700, here's hoping the 1000 gets here soon.
Reactions: pct
sharky
does anyone know what the total width-widest point- of 28x11x14 ipt rims and evol tires , shed door is only 64 7/8 wide already got tires and rims no machine yet pk1 3 seater, didnt think about the width.
67,187
Your going to be pushing it with ITP rims!
With only 2 inches to spare I would stick to factory rims.
What offset did you get?
Even if you went 1/2 inch wider on each side. You will end up scraping the door way!
BTY,
Welcome to the club!
Reactions: pct
BigRiver
BigRiver
324
79
These tires on stock rims, do you think they will clear adequately on compression of the suspension? How was the wear rate on the 700? I've always thought well of Maxxis Bighorns, but open to other brands.
They will rub without a lift, wore GREAT, but I didn't ride on pavement. Ran SMOOTH radial made all the difference offer the bias ply HBCs I had before.
BigRiver
BigRiver
324
79
So I take it that you're installing a lift?
208,728
ATV / UTV
Tire Information
Size-30x10.00R14NHS
Ply Rating-8
Load Index-96
Speed Symbol-F
Dimensional Data
I've made two mutable day rides w/ the BW's now, no busted side walls, I have never finished a ride with out a busted side wall, even with 8 plys. And that's running 8 psi on the BW's. I'm becoming a BW fan and they really hook up in slimy conditions!
