Hey all, I installed the second battery kit on my Talon R and I’m trying to wire the volt meter into the Blue Plug accessory wire and I have no power? All the fuses are fine, I know the meter works but I have nothing with the plug? Any suggestions?
key has to be on for the blue plug (for the winch to work). if it is not coming on make sure the fuse in the back isnt blown. if you have a 4 seater. remove the cover between the back seats and find the blown (smaller) fuse.
I ended up figuring this out. I had a bad connection at one of the plugs on the harness— wasn’t clipped together all the way from factory and vibrated apart.
