Talon Bouncy Throttle
PRF
PRF
New River, AZ
I have trouble holding steady with gas pedal on slow rocky trails. Has anyone found a fix or a tip to help prevent the bucking bronco syndrome!
Reactions: sharp
PRF
PRF
New River, AZ
Heel on the floor side of foot against center firewall with pressure becomes natural after a bit
Thanks for reply.
I have tried to adapt as you described, does not seem to be getting any easier with time. I dont think better foot control will be the answer for me. I have driven many different machines over this type of terrain without this much throttle bucking. Other forums like the Jeep forum suggest heavier throttle spring but I cannot find a good place to add one.
sharp
sharp
3,757
14,955
Tennessee
If its anything like the pioneer, its part of the learning curve. Your foot has to get trained and use to it. It wont take long. Although ive never used one, I think some people use a throttle max to help. Keep riding!
L
Lovetorque
68
80
Columbia falls mt
Thanks for reply.
I can break it in for you,fill the tank I’ll be right over
208,729
I added a heel support to steady my foot.
Cut a piece of 1 X 2 lumber, 3" long , cut a 45 degree angle across the face and secured it to the floor with two screws.
Works great.
I've always thought that would work, now we need to make some out of poloyer!
Reactions: sharp
Tramguage1
Tramguage1
Texan
7,498
30,726
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
20190418 163002
Tramguage1
Tramguage1
Texan
7,498
30,726
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
For s***s and giggles what size hinge is that and would the same size hinge fit the pioneer 1000? I've got the throttle maxx on my pioneer and I love it. My buddy is too cheap to buy 1 and wants to go your route.
Yes and I will have to measure it. I got this one at HD or Lowes. I think it was the largest the carried. You could use same size for Pioneer.
Reactions: TripleB and sharp
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
8" gate hinge from Tractor Supply. Cut off part of the top then cut 1/2" split down middle. I had measurements wrote down at one time but can't find them now.
  • Dislike
Reactions: Nogrey and TripleB
Tramguage1
Tramguage1
Texan
7,498
30,726
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
The Talon gas peddle is a little different. The slot needs to be offset to the left a little.the piece I cut off the left side was welded to the right side to make a spot for the bolt holes.
208,729
And after all this time after seeing your hinge, I thought you Texans were just hinged differently! HA!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Still wouldnt be hard at all to make. So easy a democrat could do it lmao
