P1000 Bussman Fuse Box/Relay
DerekC
DerekC
55
87
Little Rock, AR
Wondering if someone has advice on how they mounted their Bussman Fuse Box? I've seen a few pictures on here so I see the location a lot of folks go with, but I'm still not having luck with the fit of it all. Help is appreciated!
I will agree that my placement isn't that good but I had to because of space limitations. It's mounted to the backside of the glove box. I can still access it and change fuses fairly easy but not as easy as being mounted in the open.
Here's the view from the inside of the glove box
007ead9878d454a0e0bba712b9ea9c29
A9364509709ad8ea1ed36c113673b007
D9053710576a8338a9561a47ebd55ea3
Reactions: DerekC
Neohio
Neohio
Beast of the East
14,465
72,306
Painesville Ohio
I mounted mine to the top of the glove box. It had a decent amount of support to hang off that far. I would not suggest replicating this install unless you have a 90 degree drill small enough to drill the 2nd hole. I left mine at work and ended up wrapping the drill bit in electrical tape and spinning it by fingertip to make the hole.
IMG 20170609 183758
Reactions: joeymt33
DerekC
DerekC
55
87
Little Rock, AR
Thanks for all the great ideas guys...I went with bolting one bolt through the frame and one through the glove box. It put it out of the way but easy to access. Only the first step but glad I got it in! A0c2709d64af05c556a95d56774289c11743993ef74b37122657999cc3be7ca8551ffc3793c4ecb78eccfd2ca1ef37a7
