BOX1
P1000 Cely's 2021 P1K5 Deluxe Build
Cely1932
Cely1932
91
591
83
Loveland, CO
Started working on a few items over a week ago before Jury Duty got in the way.
Here's the short list prior to my public service......
OEM roof
OEM glass windshield
OEM soft mid panel
Graphics from The Vinyl Creator
I need to re-do part of the wing graphics on each side due to some small wrinkles.
20211211 125432 20211211 125449 20211211 125526 20211211 141403 20211211 141414 20211211 141446
Lady01
Lady01
192
487
Midland Michigan
OEM roof
OEM soft mid panel
View attachment 308948 View attachment 308949 View attachment 308954 View attachment 308955 View attachment 308956 View attachment 308957
Hood, headlight, and door graphics really cool.
Cely1932
Cely1932
91
591
83
Loveland, CO
I installed my Warn front bumper and Warn Axon 55-S winch. I even managed to stuff a Rough Country 6" light in there with a few modifications to the supplied mounting bracket and an aluminum spacer.
20211216 081607 20211216 111223 20211216 151538 20211216 151546 20211216 151556
Cely1932
Cely1932
91
591
83
Loveland, CO
Got the EMP rear bumper installed with a couple of 10" Rough Country lights mounted inside. I really like the styling of this bumper. The lights are located on the face of the bumper that points them ever-so-slightly downward.
20211217 152747 20211217 152755 20211217 152821 20211218 145531 20211218 145541
Cely1932
Cely1932
91
591
83
Loveland, CO
I'm overdue for an update. I'll probably spread this out over a few posts.
I added 3 pairs of cube lights, windshield, mid & rear. I used the brackets that came with the Rough Country lights for the front pillars. For the mids, I installed M8 nutserts in the cage. The rears involved fabricating a plate to go between the roof and cage. I also added a leftover 6" light to the reverse lights.
20211226 160350 20211226 160359 20211226 160417 20220114 100946 20220114 101000 20220114 101018 20220114 101040 20220114 101116 20220114 101147 20220114 101202 20211228 115444 20211228 154040 20220114 094621 20220110 170351 20220110 170423 20220110 170500
Cely1932
Cely1932
91
591
83
Loveland, CO
For my 2nd battery, I chose to go with an Optima under the seat. I made a mounting plate to attach an Optima specific mount that I purchased. I put a few nutserts in the steel in the floor and made some standoffs to get the plate more or less level. I have a 200A circuit breaker wired just off the battery as well as a battery tender attached to the side posts. There is also a 70A circuit breaker and solenoid for an accessory outlet I have in the bed.
20220112 111338 20220112 124739 20220114 105903 20220123 150359 20220123 150418 20220123 150435 20220210 090707 20220210 155024 20220210 172250 20220210 172307 20220210 172321 20220210 172343 20220123 150508
Cely1932
Cely1932
91
591
83
Loveland, CO
Mounting the 2 Blue Sea fuse blocks involved machining a couple of Delrin mounting blocks. I placed the "key-on" block above the factory battery & the "always hot" block above the air intake.
20220124 152743 20220124 160129 20220124 160139 20220124 161102 20220124 161131 20220125 104312 20220125 104318 20220125 104624 20220125 105914 20220125 105931
Cely1932
Cely1932
91
591
83
Loveland, CO
I tucked the relays back behind where the most have placed their auxiliary battery. The mount is attached to standoffs mounted to the steel behind the battery pocket.
I also placed a socket in the bed with a 50A capacity for various things.
20220130 161130
20220130 161159
20220127 161731 20220127 161738 20220127 161748 20220210 185433 20220208 160633
Cely1932
Cely1932
91
591
83
Loveland, CO
The tire & wheel combo has been a little challenging thus far. Buy some beadlock wheels, a tire and simply attach the two right? Wrong! The wheels are Fuel Tech beadlock 15 x 7 +38mm and the tires I'm trying are Tusk Megabites 28". The bead on the tire is too thick, so spacers will be required. Problem is, I can't find spacers for them. Fuel doesn't appear to make any & I couldn't find any other source that would fit. Oh well, do what machinists do and make them (or in my case send to the local water-jet guy). I sent the rings out for powder coat as soon as I got the wheels in. Of course that was at the end of last year and took 4 weeks with Christmas & New Years in the mix. The color is Davis Red from Prismatic. I will be picking up the spacers today after 3 weeks of waiting, so hopefully I'll have some correctly assembled beadlock tires & wheels this weekend.
20211212 131604 20211214 180301 20211214 180312 20220117 163337 20220117 163356
Cely1932
Cely1932
91
591
83
Loveland, CO
I picked up the spacers Friday for the beadlocks. They turned out great, well worth the 3 week wait. They are an 1/8" thick, 6061 aluminum. The beadlocks are nice and flat with these installed and properly torqued. I may have to give in to my little voice telling me to put them on ASAP instead of finishing the wiring I'm in the middle of......
20220211 094646
20220211 102138
20220211 102153
WagginTail
WagginTail
1,456
5,379
SC
Reactions: JenElio and Lady01
Cely1932
Cely1932
91
591
83
Loveland, CO
Time for a much needed update to this thread. These may or may not be in chronological order......
I installed a Trail Armor skid plate. For the most part, installation was a breeze. I opted to install 6mm NutSerts on the frame instead of the self-tappers that were supplied. In order to ensure the holes for the inserts were centered in the holes on the skidplate, I made a drill bushing that was a snug fit to the 1" holes.
20220223 133722
The only factory hole that I had trouble with was the rearmost one on the passenger side. It was off center by almost a 1/4". I believe others have had issues with this same hole. I machined a new pocket/hole in the correct location in the skidplate.
20220223 131723
20220223 133317
Next I had to trim the front of the side panels, directly behind the front wheels to eliminate rubbing at full lock.
20220223 124013
20220223 110758
20220223 120341
20220223 120411
Overall, I'm very pleased with this skidplate.
20220223 135232
20220223 135320
20220223 135445
Cely1932
Cely1932
91
591
83
Loveland, CO
I added some Tusk side mirrors & Honda center mirror, PowerBass XL 1250 soundbar, Haltron fire extinguisher, ThrottleMaxx, Hillbilly Brake and a Blac-Rac gun rack.
20220223 190046
20220223 190053
20220223 190121
20220223 190131
20220223 190108
The Tek208 fire extinguisher mount is a slick quick detach mount. I had to open up the clamp ID from 1.75 to 1.80 to fit the ROPS at the rear passenger, DS location.
20220303 144315
20220303 144403
Next was the PowerBass XL-1250 sound bar. Mounted on center ROPS, facing forward. Very happy with the sound.
20220303 162726
20220303 162738
20220303 162805
Next up is the HillBilly Brake and ThrottleMaxx. No pics of the brake.....
I made a couple of standoffs for the ThrottleMaxx so the screws could be fully tightened without bending the upper bracket.
20220228 130204
20220228 124449
20220228 130601
I installed a Blac-Rac rifle rack for my AR. This thing is awesome! I, once again, had to open the clamp ID from 1.75 to 1.78 to properly fit the ROPS over the windshield. An AR mounts in this with a 30rd mag inserted and opens and closes without hitting the ROPS or center mirror.
20220303 121427
20220303 121443
20220303 121457
20220303 121512
Cely1932
Cely1932
91
591
83
Loveland, CO
More updates. Installed the OEM wiper and a Kemimoto washer tank/pump. I didn't use their included sprayer because it shoots two streams of water, not a spray. I purchased this one from Amazon. I wired the wiper and washer through a OFF-ON-(ON) switch using the wiring diagram another club member posted. Works great!
28372eca505fc83827bb1592efbfa2a5
I placed the tank where most a placing the auxiliary battery. I had to make a mounting plate and install a few NutSerts.
20220304 141555
20220304 141821
20220304 142438
20220304 151112
20220304 151201
20220305 183639
20220305 183644
20220305 183653
20220305 184035
20220307 142904
20220307 142926
Cely1932
Cely1932
91
591
83
Loveland, CO
I finally installed the switch panel. It's made from 1/4" aluminum so I could add a generous chamfer around the face and have a more unique look to it. Black basecoat with silver carbon fiber hydrodip.
20220218 091051
20220218 091100
20220218 091108
20220303 162634
20220303 165957
20220309 102337
20220309 105127
20220309 105420
20220309 115825
Cely1932
Cely1932
91
591
83
Loveland, CO
I really like this build but I can't wait to see this machine get dirty
OMG, tell me about it! It's hard walking out in the garage everyday wanting to ride it. I'm on the last major project, and that is to get the seat mount made & any harness required to mount a custom seat for our special needs son. I sent the aluminum out to get bent just this morning. Sucks not having my old shop available to me......
Seat Riser Assy ISO
20220309 115850
20220309 115920
BOX2
box3
