Code Reader
TxDoc
TxDoc
1,604
5,558
TEXAS 🇨🇱
photos.app.goo.gl
There is no code reader like a car's OBDII reader, is there?
You must count the long and short flashes on the dash.
Longs are tens and shorts are ones.
Thanks
Reactions: Lady01 and wrhii
HondaTech
There are some options out there but none that I've found for offroad stuff.
Most of the tools will only read on road product and then your at the mercy of the manufacturer of the tool to update for new models.
41,587
The Power Vision claims to be able to display dtc's on whatever vehicle it's married to.
Reactions: Lady01
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
Yes
Honda has a fairly simple way of doing this with the DCT (diagnostic trouble code) part# 070PZ-ZY30100. Its just a plug with a jumper on the end of it. You can read and clear all stored codes. It comes up on the gauge cluster. The stealerships use the same $9 tool.
TxDoc
TxDoc
1,604
5,558
TEXAS 🇨🇱
photos.app.goo.gl
Interesting. Thank you
41,587
Sorry @TxDoc I thought you were aware of this. Simple paper clip or jumper wire. If the 1000 is like the others, You don't get the sub code like you would with a "scanner", but it still gives you a place to start.
Reactions: Lady01
HondaTech
We only use that if the unit isn't MCS or HDS compatible. Which nowadays will only happen on older (pre 2004) units. And some older ones had a 2 pin connector to short instead of the current 4 or 6 pin.
The MCS let's you do much more than read and erase codes though.
Reactions: Lady01 and TxDoc
TxDoc
TxDoc
1,604
5,558
TEXAS 🇨🇱
photos.app.goo.gl
Thr MCS let's you so much more than read and erase codes though.
I learned something new. I appreciate the information on anything I haven't seen before
Reactions: Lady01
Hawk53
Hawk53
461
587
Alberta Canada
What is the cost of a MCS ?
