P1000 DEI heat shield at Jegs
115,818
I don’t, but what I did and many others have.. if you search in the magnafine glass for bilge fan on this site you will find that there’s many inexpensive DYI ways on how to do that yourself. There is a member that sells these heat shields on EBay for around 30$ the bilge fan runs about the same if you look on amazon. All you’ll need is a bracket you can easily make any way you like and a switch to turn it on and off. Or if you want to spend more money, just buy the kit on jegs. Either way, we’re all here to help you out.
115,818
Skip Jegs and contact DEI themselves.
They are a forum sponsor now. Check the vendor section for their code.
@DEIDan
I apologize, I didn’t know they were a Sponsor. I was just trying to help with how I did it.
Neohio
Neohio
Beast of the East
17,824
86,022
Painesville Ohio
@Remington no need to apologize, I went another route as well. I figured he asked for DEI, so I suggested he contact our forum vendor vs going to jegs.
Reactions: Remington
L
LarryAmboy
903
2,007
Castalian Springs, Tennessee
I’ve got their heat shield and it is a much better quality than the eBay one (sorry). I can recommend it
Reactions: Hondasxs and Bones
Bones
199
203
Bourbon Mo.
Installed the heat shield and it made a big difference not only in heat but also sound deadening. Worth the money and time to do it. Doubt I'll need the fan.
Reactions: JTW
Neohio
Neohio
Beast of the East
17,824
86,022
Painesville Ohio
Can you post some pics of it? It looks like actual heat shielding vs the bubble wrap insulation we have all used.
Bones
199
203
Bourbon Mo.
It is heat shielding. It's about 3/16" thick. They did a pretty decent job putting all the holes in the correct position so you can lock it down with the stock push pins. If you have the Honda rubber fix that needs to go away for this install. Like I said, big difference in engine noise too. Noticeably quieter and cooler. I'd recommend it and if you do buy it watch the video, the paper instructions aren't great. Got it from Jegs.
IMG 2738 IMG 2739 IMG 2741
Reactions: Hondasxs
