P500 Diff synthetic oil recommended P5
Steve00
Steve00
64
91
Florida
Riding a lot in Florida wanting to keep diff cool and quieter suggestions for synthetic oil for front and rear diffs and brand/weight
906UP
906UP
14,399
136,822
da Yoop
I used Valvoline Synthetic 80W140, it does help quiet the rear diff a little but not much.
Reactions: Remington
43,292
On a related note: My rear diff gets super warm. Its full of oil. Does anyone else notice this?
I never really checked the heat on my old 700.
rtn001
rtn001
317
945
Central Florida
I'm in Central Florida and changed mine out using Lucas 75w140 synthetic in the diffs and Pro Honda HP4S 10w30 synthetic the engine. I was talking to the service mgr. at the dealership and told him I was changing to synthetic. He said he used the Lucas synthetic and the Honda synthetic oil in the engine in his. He repeated the use of Honda oil several times in the conversation. I got the feeling he was trying to tell me something without saying it. It sure quieted the Diffs down as everyone has said it would. I couldn't find the Lucas 75w140 locally and ordered it online and got the Honda oil from the dealer. Next time I will get it all on line as they are sure proud of it at the dealer. Just remember that the synthetic diff grease must be of a type that mixes with standard diff grease (no need to flush), it will say so on the bottle if I remember correctly and the engine oil must be of a type that works with a wet clutch. There isn't anything to changing it out, even I could do it. LOL Have fun! I do. I love working on the little beast. I haven't noticed any overheating but I haven't really checked anything but the engine temp.
Reactions: trigger
SouthParkColorado
SouthParkColorado
151
648
Hartsel, CO & Aurora, CO
www.flickr.com
  2. Other Brand
https://www.amazon.com/gp/product/B009IF3KFK/?tag=sxsweb24-20
Mobil 1 102490 75W-140 Synthetic Gear Lube - 1 Quart
Product description
Size:1 Quart (32 Ounces)
Mobil 1 Synthetic Gear Lube LS 75W-140 is a premium performance, synthetic, multi-purpose, automotive gear lubricant designed to meet the highest level performance requirements of many modern passenger vehicles in all types of operating conditions including limited slip applications, as well as deliver outstanding power transfer performance. Compared to conventional hypoid gear lubricants, Mobil 1 Synthetic Gear Lube LS 75W-140 performs exceptionally over a wide range of temperatures. Mobil 1 Synthetic Gear Lube LS 75W-140 achieves this through a unique proprietary combination of synthetic base oils and a unique additive system, including the SuperSyn anti-wear system, that delivers optimized viscosity-temperature properties together with the highest level of inherent formulation stability and protects against thermal and oxidative degradation, wear and corrosion, and viscosity loss associated with premature shearing. Mobil 1 Synthetic Gear Lube 75W-140 LS contains special friction modifiers designed for limited slip type differentials. In most applications, the addition of special LS (limited slip) additives is not required. For axles requiring the highest level of limited slip performance, OEM specific LS additives can be added to this fluid.
Reactions: rtn001
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
There are many quality synthetic oil choices as stated above, just keep in mind, it needs to be hypoid type.
Reactions: AlR and rtn001
AlR
AlR
470
1,166
Nanaimo, British Columbia
Hypoid hypoid hypoid. I did a diff oil change last week. Used the 80-90 I had in the garage. Looked at the container today it said 'limited slip'. Went to Lordco and bought the expensive Royal Blue stuff. It said 'not for ATVs'. Gawd... so went to Honda and bought their gear oil. There is raised lettering on the rear diff that says 'hypoid'!!
I'll find some nice synthetic hypoid oil when I have more time. Gotta get the rig ready for this weekend!! Thanx for emphasizing HYPOID.
Al
Reactions: trigger
T
twodog
Ozark Mountains
I am about to do my first differential oil change and have noted the discussions above about hypoid oil. I have a stupid question though. I have looked and looked where is the rear differential drain plug. Is it on the bottom and accessed through the skid plate? I think I feel a plug there but have not jacked up the back end so I can see?
G
Gassygordo
302
1,025
Fillmore, NY
Yes it is, but I had to flip my skid plate over in order for the drain plug to line up with a hole. I think Honda installed that short pan up side down!
Reactions: trigger
182,261
Yeah, there's a hole under there but it doesn't line up very well. I think I pulled the two back bolts and tipped it down so it didn't run all over the place.
Reactions: Eltobgi
V
vinnie55
dubuque ia
Just take a hole saw the same size as the hole next to the rear diff drain plug and than make it an oblong slot by using a sharp utility knife.
alloutdoors
alloutdoors
1,022
2,184
US
If you are still planning on doing the differential change, I would suggest doing a good cleaning of the unit (be careful at the car wash), but I would get all the mud/debris out making it a bit more enjoyable and keeps unwanted materials out....
Reactions: DaddyDubbs
T
twodog
Ozark Mountains
Already done it several weeks ago. I have a pressure washer and clean the 500 after every ride so that is not an issue for me. I ended up using Honda gear oil as it was cheap enough and readily available. The differential is noticeably quieter now and shifting much smoother.
16p500
16p500
59
235
Florida
How many bottles did you have to buy? I plan on doing both front and rear.
Neohio
Neohio
Beast of the East
17,909
86,414
Painesville Ohio
One quart should leave you with leftovers.
Capture83
