P700 Door latch bolts falling out.
swsebek
swsebek
2,854
5,835
pa
IMG 3400
I remember when The 700s came out a lot of guys had latches loosening up and bolts falling out...I had a couple loosen on me early. But nothing for 2 years now today one was absent from passenger side...
IMG 3401
but lucky for me I have a few extra:D just thought I would remind all to check em.
IMG 3404
43,292
Never had that one come loose, but i did have the ones in the upper right of the 2nd pic come loose. Took like 6K miles though.
Rinconruss
Rinconruss
40
64
Lakeland Florida
I had that same bolt come loose on the driver's side a few weekends ago. Luckily it got stuck in the latch cover and I was able to put it back in. When I got home i pulled it out and put a little lock tight on it. Guess I should do the passenger side as well.
Mudwing
Mudwing
36,959
306,672
The Mud holes
On bolts like these, would you use red or blue Loctite?
swsebek
swsebek
2,854
5,835
pa
IMG 3385
I use red (515) on everything but just a shmeer in the threads. But follow the manufacturers directions. Don't ever put too much on and it goes on the latch mechanism and locks it up too.
I like the gel better.Tastes good too;)
Reactions: Mudwing and R-Lamm
swsebek
swsebek
2,854
5,835
pa
We road all weekend getting fire wood and playing and when I notice it was loose my wife and daughter said it wouldn't close rightfor them:confused:but didn't tell me:D I expected to find it laying there too.....I have lost frame caps,Seatbelt plastic covers,Side mirrors,and a couple lug nuts and got lucky and found them again.....Even lost my Oil change cover and my boy found it and threw it in creek for me to retrieve.
Reactions: R-Lamm
Rinconruss
Rinconruss
40
64
Lakeland Florida
I lost a part that I have have been looking everywhere for a replacement. Under the bed, on the frame just below the seat back, are 2 rubber bumpers that the bed sits on when it is closed. One of them came off. I looked at a number of OEM parts websites and even went to my local dealer. Cannot find it anywhere. I ended up cutting a chunk off of an old flip flop and zip tied it to the frame.
Reactions: Mudwing and swsebek
Rinconruss
Rinconruss
40
64
Lakeland Florida
I used red. To keep the loctite from messing with the latch, I used a tooth pick and put a small amount on the threads that the bolt goes into. If you putt the loctite on the bolt there is a chance of it getting in/on the latch and causing it to stick.
Reactions: swsebek
