Does anyone have the soft doors?How is fit? I read some reviews that said they was poorly made and didnt fit right?Just wanted to find out if they are worth getting?
how much do these doors cost?I have a set of the soft doors. I looked at them as a must for the weather conditions here in AK. I was also concerned about some poor reviews that I had read, but after installing them, I was pleasantly surprised. Yes, there are some gaps. Yes, there is some leakage. Yes, they do "bellow" a bit in high winds. However, they block 90-95% of the rain, and 90-95% of the wind. This makes them great to me. I can ride in 45 degree, sideways rain with "normal" clothing on. I don't have to pull on head-to-toe rain gear, long johns, goggles, etc. My P500 is my primary transportation here on the island, and it would be a pain to have to "suit up" every time I ran to the store. Ha! Installation was not too bad, and fit/finish was better than expected. I was looking at ways to better seal doors, soft doors , windshield etc., but have decided to live with a few drafts, as this keeps the windshield from fogging. If you live in a "inhospitable" climate, I would recommend them.
They are $449.95 MSRP @ Honda. They're a little more if you want them in Phantom Camo. You can find them cheaper on Amazon, or can buy them at below that cost at a dealer, if they will dicker with you.how much do these doors cost?
$449.95, is this per door or for 2?, if this is for 1 door I will make my own that will fit better than factoryThey are $449.95 MSRP @ Honda. They're a little more if you want them in Phantom Camo. You can find them cheaper on Amazon, or can buy them at below that cost at a dealer, if they will dicker with you.
That's for a pair. Ha! Even Honda doesn't gouge you like that.$449.95, is this per door or for 2?, if this is for 1 door I will make my own that will fit better than factory
I would guess if their cooler is full or not.....thanksThat's for a pair. Ha! Even Honda doesn't gouge you like that.
@p500fan how hard are they to install and remove[/Q
They are't too bad to install, just a little awkward to hang by oneself. Having a helper would be advisable. (Tough being on both sides of the door at once.) Once you get everything positioned & tightened down, you can "un-hinge" the door frames to remove/re-install in just a few minutes by yourself. Hanging the hinges is the booger! I changed wheels/tires, installed the roof, windshield, rear panel, and cargo tray in 3 hours. Took 4 hours to hang/adjust doors to my liking. However, that could be due to the OCD my wife is always complaining about. Ha!
Oh please tell me its not true ive never once had a good experience with optima of have any or the guys i raced with they would all last about a mth or to then stop holding a charge this was with yellow and red tops i hope for you that they have changed and will hold up for youif my Optima battery comes in.
i have only heard good things about the optima batteries.... i hear they are the best battery you can buy.... but i have never used oneOh please tell me its not true ive never once had a good experience with optima of have any or the guys i raced with they would all last about a mth or to then stop holding a charge this was with yellow and red tops i hope for you that they have changed and will hold up for you
