Talon Double Shear Brackets
IDIOT
IDIOT
280
755
Kingman, Az.
Got the Shear Stoppers Installed this morning, I think they are gonna do the Trick.
IMG 5578
Reactions: TripleB
Sheetmetalfab
Sheetmetalfab
2,227
14,032
Alaska
They hit both brake caliper bolts.
only fit the talon R
Reactions: IDIOT
IDIOT
IDIOT
280
755
Kingman, Az.
That's what I was wondering, if they just mount together, I don't see them doing anything.
They are bolted in 2 places to the hub, should theoretically make it stronger, time will tell i guess.
HondaTech
Are people bending or breaking those bolts? Or is it a "just cause" thing?
These brackets are suppose to be the other side of the hub that would make the radius rod joints "double shear" instead of single.
Double shear mean the joint is supported on both sides by the mount. The talon only has the hub on one side of the rod, making it single shear. Alot of other models have double shear points.
Jefferson87
Jefferson87
258
275
Northern California
  1. Talon X4
I fully understand what double shear means. Thank you. :D
What my point is, if the bolts are strong enough, and properly tight, the double shear isn't really necessary.
Reactions: lee and JACKAL
PhilCod
PhilCod
354
729
Indiana
I purchased as set of these for my X from McNasty Customz. Theirs is also designed to protect the CV boot from behind.
Sheetmetalfab
Sheetmetalfab
2,227
14,032
Alaska
but all they do is tie the two bolts together.
nothing to the brake caliper bolts.
Reactions: IDIOT
CMB
CMB
5,108
55,092
Ohio
  2. Talon X LV
Where did you find them for the R ?
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
PhilCod
PhilCod
354
729
Indiana
My bad, you said R not X. The McNasty's are for the X.
jamesh
jamesh
253
350
DFW
They'll distribute the load so it is more shared with other single shear bolts. One pic of a broken hub was shared on facebook and then a handful of accessory companies rushed these things to market. Probably unnecessary, but doubt they'll hurt anything. One more thing to scoop up and carry mud around.
