P1000 Dragonfire XT300 tires
Rangejunkie
Rangejunkie
44
108
Jackson, MS
Has anyone tried these tires yet? How true to size are they and how well do they do?
Xt300 extreme trail tire 5
Reactions: Isaiah
LaVell
LaVell
181
369
Opp, Alabama
Been thinking of getting those myself. From what I have read they run pretty true to size. 8 ply so should hold up well.
Reactions: Rangejunkie
jwfirebird
jwfirebird
927
1,446
western ny
looks like a super swamper, ratings seem ok and fairly light for the size, most tires like that give you some vibration at least till there worn down a bit, radial 8 ply seem pretty good
SIZE - PLY RATING - DIAMETER - TREAD DEPTH - MAX PSI - MAX LOAD - WEIGHT - PART #
27 X 10R-14 - 8 ply rated - 27.4 in. - 0.75 in. - 18 psi - 942 lbs. - 32.1 lbs. - 521436
28 X 10R-14 - 8 ply rated - 28.4 in. - 0.75 in. - 18 psi - 1,002 lbs. - 33.4 lbs. - 521437
30 X 10R-14 - 8 ply rated - 30.2 in. - 0.75 in. - 18 psi - 1,134 lbs. - 39.6 lbs. - 521438
32 X 10R-14 - 8 ply rated - 32.2 in. - 0.75 in. - 18 psi - 1,293 lbs. - 41.8 lbs. - 521439
33 X 10R-15 - 8 ply rated - 33.1 in. - 0.75 in. - 18 psi - 1,350 lbs. - 45.3 lbs. - 521440
