G
Installed my True isolator and Odyssey battery. I drilled and tapped a hole in the frame to ground the Odyssey, and everything works, including the dual voltage meter setup.
My question is : I originally ran the ground from the negative side of the Odyssey to the negative terminal of the factory battery, thinking I would 'pick up' the ground to the machine there.
But then I began to wonder if I wasn't defetaing the isolator by connecting the negative of the two batteries.
Does it make any difference? is one way better than the other?
Thanks!
Thanks!
