BOX1
P1000 Engine cutting off when stopping
Sloganuga
16
14
Leesburg, GA
2017 1000-5 deluxe with 500 miles. Started this weekend and has done it 5 or 6 times today. When slowing down and coming to a stop the engine will die. Usually will not start back up unless you turn key off and then back on. Also noticed the rpm gauge is doing some weird movement when turning the ignition back on but before starting. Any ideas on this one?
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Loose electrical wires or bad Air Filtero_O or bad Spark plugs, or plugged spark arrestoro_O
Tell us about your service historyo_O
Sloganuga
16
14
Leesburg, GA
A bit of additional info. It also most seems like the clutch is not fully disengaging when coming to a stop and thus bogging and dying. Also the shift points are changed (lost shift memory) upon restarting.
ohiohunter
ohiohunter
103
141
Minerva Ohio
I would look at grounds on battery or battery its self.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
If it keeps dying and you still have a warranty bring it back in.
13,244
63,664
@Sloganuga
Do you know how to record the diagnostic trouble code? Try taking a quick cell phone video of dash panel when it dies. That will tell us your code and will allow us to help diagnose your issues.
Sloganuga
16
14
Leesburg, GA
Thanks all. I went ahead and put the battery on charge at lunch and will check the grounds tonight (hopefully). Neohio, I will check for trouble codes and let everyone know. I don't know how off the top of my head but have the service manual at the house. I assume it is just a blink pattern on the display?
13,244
63,664
Correct, long blinks are units of 10, short quick blinks are units of 1.
Add them all together and hit the service manual for direction.
Sloganuga
16
14
Leesburg, GA
Checked when I got home this evening and no codes are being thrown. Embedded is a video of what the display is doing after the engine shuts down. Note you can hear the clicking of a relay in the background. It appears to be the fuel pump relay opening and closing repeatedly.
GerryC
GerryC
5
9
This going to sound weird....but be absolutely sure you are not left foot braking and touching the accelerator pedal at the same time inadvertently. There is a built in program in the electronics for clutching that is a default to more serious issues. If you do it more than "X" number of times, the default kicks into a limp home mode. It happened to me twice in first 200 mi. Once I figured it out it never happened again. Hoping you are that lucky too.....just sayin
Sloganuga
16
14
Leesburg, GA
Quick update. The problem continues to get worse. Now it will shut off when stopping or starting. You have to gently get it going or it will die. Also noticed you can hear a humming after all power is off and key is removed. Sounds like the fuel pump pressurizing. Shifting is also jerky. It killed the battery last night so charged it up and took to the shop to hopefully get it repaired under warranty (5 months old). Service manager said about a 2 week backlog. I'll update when they figure it out.
Sloganuga
16
14
Leesburg, GA
Over 2 weeks at the shop now and they cannot figure it out. They had a call in to Honda and waiting to hear back...
evildoctor
evildoctor
61
94
NC
Any updates? I'm having the same issues with it cutting off minus the weird sounds and all that. It cuts off during driving and would only restart when I turn the key back to the "off" position and restart it then. Found a few posts pointing the issue to be a faulty fuel injector plug wire.
HondaRed16
HondaRed16
250
487
Arizona
You nailed it. There is a neat little repair plug here at the store. Get those (2) at least you should be good to go
Reactions: evildoctor
41,533
Mine makes weird sounds when it cuts off. It's like it farts through the muffler, sometimes. Or maybe that was me...
HondaRed16
HondaRed16
250
487
Arizona
My pioneer 700 was doing it. Took it to the dealer, was a loose battery cable.
Yep, it can surely be a loose battery post/connection or bad ground.
But in most cases with that year it's the injector harness, it's not if it's going to go bad it's when. The repair kit is cheap and easy, everyone should be carrying one in their toolbox.
BOX2
box3
