P1000 Engine timing
Leea706
Leea706
9
10
Monticello Ga
I have 2016 pioneer 1000 with 40 hrs on unit. My wife and I accidentally sunk the unit in water. I have repaired the engine but having trouble getting crank and camshaft back in time. Can anybody help me?
Reactions: BWAF
Eltobgi
Eltobgi
4,599
15,186
North Dakota
BA5E393E 38C7 46BE A3C7 A8EDE7901C4E
C7154351 6F99 4471 A384 5E1AAC61FF71
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Thank you so much! I’m going to try timing it today. I will let you know my results.
You are welcome! But, I consider it a responsibility and privilege to help a fellow club member:cool: Now get that thing started and RIDE;)
Leea706
Leea706
9
10
Monticello Ga
I’m still having trouble getting the engine in time. Any pointers would help please
Neohio
Neohio
Beast of the East
13,304
64,428
Painesville Ohio
Are you asking for ignition timing? Or for the timing chain installation?
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Have you followed each step exactly? Including aligning index mark with FE, double checking correct cam sprocket position?
@snuffnwhisky any ideas?
@CumminsPusher @HondaTech
Neohio
Neohio
Beast of the East
13,304
64,428
Painesville Ohio
@Leea706 Please upload some pictures of your setup, and where you are having issues. Use a pen, or knife to point out what we think we need to look at.
Why do you think your engine is still out of time?
Reactions: Eltobgi
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Under the seat is a big plug on the case that you need to pull out. Inside is the crankshaft nut to turn the motor with. I believe beside that is another plug u pull out for an inspection hole to get you on top dead center. Once the crank is aligned, align the cam gear.
Reactions: Eltobgi
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
I'll find the page on it.
Reactions: Eltobgi
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Here's a pic of the plug to access the crank nut. Pretty sure the inspection bolt is right there beside the {1} on the top left of the round cover.
Nut
Reactions: BWAF and Eltobgi
Leea706
Leea706
9
10
Monticello Ga
I have it timed now and running but I believe I have a bent rod because she is making some noise on the bottom side. Just my luck I guess. Thanks for all the help
Reactions: Eltobgi
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Do a compression test and the oil pan is pretty easy to pull off in the rig. Almost everyone I saw swamped bent a rod. Ebay has used motor parts most of the time.
Leea706
Leea706
9
10
Monticello Ga
Well thanks for all the help she is really done now! It slung a rod through the block when I started it again. I will now be looking for a upper block along with engine rebuild kit. Any suggestions where to get those parts will be very appreciated.
Reactions: Eltobgi and BWAF
63,326
Damn. Sorry to hear this.
I've see a few totaled ones pass threw some auctions. Might be worth hunting down one.
Wish you luck.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
:eek:Also sorry to hear @Leea706 :( I will keep an eye out for the parts and post here if I see anything.
How about some pics of the damageo_O
Reactions: BWAF
