P1000 Engine water port
O
oldgasser
53
77
Arizona
Hi There: I'm hoping a Honda tech guy can answer this. I just had the Clutch and heat upgrades done to my 2017 LE. Being an old school guy and having had the engine overheat once because the auto fan module failed I would like to add a manual temp gauge. I asked the service manager if there was a plugged water port in the head of the 1000 engine and he didn't know. Before I go looking I thought I would ask on this forum. If there is one what are the size and thread pitch? I'm not that impressed with the little 4 bar temp indicator and it prevents me from using the other functions when driving because temp is a critical item when driving.
Old Gasser
Reactions: BWAF
Eltobgi
Eltobgi
4,599
15,186
North Dakota
96854BCA A4AE 4CA7 8ED2 9B8F4FAE3826
Neohio
Neohio
Beast of the East
17,718
85,388
Painesville Ohio
Capture1
arrow pointing at coolant temp sensor.
Might be able to find a metric 18mm tee fitting and fab something up that way. (don't quote me on the threads, just a guess)
Not sure if there are other ports.
popeye
popeye
3,275
14,644
kapowsin, Wa
I think you might be mistaken, believe that arrow is pointing to the bleed screw, witch has a 10mm head, so m6x1.25 maybe they make a sender that small. But the stock bolt is sealed with a copper washer. I don’t think it uses a o-ring to seal
Reactions: BWAF
Neohio
Neohio
Beast of the East
17,718
85,388
Painesville Ohio
You are correct, the arrow is pointing at the bleed screw, right next to it is the ECT. If you remove that, it will be a larger thread that should be easy to convert for either mechanical or electric temp sensor. I would take it a step further, and see if I could tap into the factor wiring and find a gauge that will work with those signals.
Reactions: BWAF
O
oldgasser
53
77
Arizona
Hi There: Thanks for the reply. I may pull the existing temp sensor to get thread size and pitch and just replace the factory sensor with one for a gauge. I won't have any further use for the factory temp gauge unless there is some safety feature that causes computer to alter operating system without temp info.
Old Gasser
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,864
42,477
Carthage MO
Old Gasser
I bet it will change something amount of fuel injected ,fan going on and off
69,237
Why can't all immigrants be like you? Wouldn't have to build the wall!
Neohio
Neohio
Beast of the East
17,718
85,388
Painesville Ohio
Yup, if it always thinks it is cold, it won't switch open/closed loop, it may even put the bike into limp mode.
Reactions: BWAF
Neohio
Neohio
Beast of the East
17,718
85,388
Painesville Ohio
On the other hand, if computer thinks it is overheating. It will constantly run the fan. I would have to check the service manual to see if it has other temp sensors. There might be one for the fan as well as the gauge.
Reactions: BWAF
O
oldgasser
53
77
Arizona
Yeah probably so. I guess the answer is probably to replace the drain plug with a gauge sensor.
Old Gasser
Reactions: Mudwing and BWAF
G
gpd2111
20
22
US
Koso makes inline temp gauges. Basically you cut the coolant hose coming from the engine to the radiator and put their tee in there then the temp gauge attaches to the other side of the tee. I have used these on several motorcycles and they work great. Just need to know the size of the coolant line
Reactions: BWAF
