Ragnar406
The Great Bald One
i picked up a couple of axles (call it planning for the future) when a good deal presented itself. Knowing that hopefully I would not have to use in the immediate future but would most likely haul In the truck when I go ride - I knew the cardboard boxes they come in would not last through a few load unloads so I began looking for options.
I first ordered a dragon fire racing axle bag for $20 - nice but it really does not offer much protection for the axle except for basic cover. So I built one tonight out of PVC. First I’ll say if you can find some thinner walled PVC you might go in that direction. Otherwise I think this has the potential to give good protection for spare axles.
Materials used
I cut a 4” circle out of the plank foam and I am trying it out as a stabilizer, it has a hold cut in the middle for the axle shaft and goes around the axle shaft in the middle of the tube.
I taped the cotter pin and o ring into tha cap for easy access.
One axle tube that can be tossed in back of truck with out worry of something damaging the contents.
Lastly I write on the outside of the tube which axle is stores inside (front, rear R, rear L)
Materials used
- 4” PVC tube cut to 29”
- 4” convex tube cap
- 4” screw cap and connector (probably not the correct terms)
- Pool noodle
- Clear tape
- Plank foam (this part still working on - and maybe don’t need)
