P1000 Fan override switch
Rhino-F350
Rhino-F350
34
41
Hello all , been lurking here for a while now and have a question about the fan override harness from the club store. I purchased awhile ago and want to install but don’t have directions , it is plug and play , but don’t know where the small yellow wire form switch goes. Any ideas or help is appreciated, thanks in advance.
Russ989
Russ989
22,642
147,257
I’m getting ready to do that, I’ve had mine for months. I’ll post up pics when I do it.
Reactions: Rhino-F350
I
ImHowl
14
78
Connecticut
This is from the HondaSXS store.
Hello, We are currently on Vacation June 24 - July 6.
You may view the store and even place a order if you wish.
All orders will not ship until the week of July 8th!
hopeicanaffordthis
19
79
Harpersfield, Oh
Its optional and for the bottom switch backlighting if you wish. Top backlight is on when fan override is on.
Hey @Hondasxs, if i have a second fuse box does yellow wire just get connected with red wire supplied? or would i want to attach to relay powered by main fuse box (jumper in key on fuse)? thank you in advance! love the switch, was super easy to install.
Reactions: Lady01
67,170
Yellow wire can be pulled from any switched source or dash lights. Yes. You can connect it to the red wire if it is switched after a main relay.
We make these so users without the full fuse panel package can wire them to the battery. So we made the bottom backlight as optional.
Reactions: Lady01
