P1000 Fan
Tuco69
Tuco69
1,474
7,565
Middle Georgia
Just put on the hard rear panel, an have the split windshield. Any body use a small fan in the cab you can plug into the accessory plug port? If so what type? Had the cabin comfort recall done an helped. Thought a small fan would move some air around. We here in Georgia have “air you can wear” in the summer otherwise known as a slight humidity problem.....,,,
TimG
TimG
OLD SKOOL
795
4,006
Southern Indiana
IMG 0128
I installed these RV Truck two speed fans. I mounted them upside down to a piece of 1/4" hard plastic, drilled a 5/16" hole in the middle of the mount between the two fans and they mount to the same TSC mount I use to mount my rear view mirror to with one 5/16" bolt attaching the fans to the mirror mount. Easy on and off. These came with a 12 volt cigarette lighter plug in so I spliced the two fans into one 12v plug in for easy in and out,all one unit. These work great and cost about $25 each shipped from ebay so I've got $50 bucks in this. Get the heat shield and exhaust fan to put under your seat also the factory rubber solution is crap and you will be a happy humid rider like myself ! View attachment 82361 View attachment 82362 View attachment 82361 View attachment 82362 View attachment 82361 View attachment 82362 IMG 0129 IMG 0130 IMG 0131
Reactions: Vaden01 and Yankee
Tuco69
Tuco69
1,474
7,565
Middle Georgia
Can’t open links?
Vaden01
Vaden01
126
299
Callahan, FL.
Road Pro Tornado is what im using. Bought of Amazon for $30. Variable speed from light breeze to serious gust!!!!! Little noisy but works well. Plugs into 12v outlet with 10 ft cord.20180807 182012
