Finally got the pods mounted
IDIOT
IDIOT
280
755
Kingman, Az.
Thanks to HavasuDave for recommending the mounting brackets i was finally able to mount my LED pods.
IMG 5850
IMG 5858
IMG 5860
IMG 5867
PhilCod
PhilCod
354
729
Indiana
Part Number? Or link to buy the brackets?
Thanks!
IDIOT
IDIOT
280
755
Kingman, Az.
CTDpower
CTDpower
341
807
Gypsum, Colorado
kinda related... anyone know of a cage mounted spot light similar to the spot light you would find mounted on a police car? I basically just want a 4" led pod on one of those unity swivel mounts that can clamp to the a pillar cage bar.
IDIOT
IDIOT
280
755
Kingman, Az.
I am not sure where you would find something like that, maybe just do a google search but i'm sure you probably have tried that already.
IDIOT
IDIOT
280
755
Kingman, Az.
Be advised the nilight brand pods i have mounted are trash so don't even bother with them. Worst led i have ever seen. I have something different on the way that should do the job.
We appreciate the heads up. Let us know that the replacements satisfy you.....👍
Reactions: IDIOT
GreenTX1000R
GreenTX1000R
79
98
Texas
Like the pods what did you do for the switch inside your cab.
PhilCod
PhilCod
354
729
Indiana
I'd be interested in knowing what kind of LED pods you get a well. I have a cheap set on my bumper. They work, but the left one has water in it already. I swear the next set I get I'm going to go around the lenses with clear silicone calk, and cover the screws as well.
PhilCod
PhilCod
354
729
Indiana
I used a relay and ran the trigger wire to the bight light wire plug right under the hood. There is also a kit you can buy on this site that lets you do this as well. I did it this way as I don't like adding another switch. So when I hit the stock switch to the brights, my led lights come on too. Obviously with a relay the power for the LED lights are from the battery/voltage rectifire.
208,730
I'm looking to get some pods for side vision that aren't to bright riding behind another rider, got a 20 inch Black Oak that's way to bright for that, got any suggestions?
IDIOT
IDIOT
280
755
Kingman, Az.
Very happy with these......https://www.amazon.com/gp/product/B07ST8WBBM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
208,730
I couldn't the link to work? Can you use them behind another rider?
IDIOT
IDIOT
280
755
Kingman, Az.
They are pretty bright but if you had them directed off at a 45deg angle i think you would be ok. Sorry about the link, not sure how to get it to work. I bought them on Amazon.
208,730
Those are nice mounts, the location of yours won't work for where I mostly ride, you think they would work on the B pillar, you if I mounted them pointing at each other and the pods pointed on a 45, bet I would have to build some spacers between mounts and pod to able to tun turn them that far?
208,730
I run the mirror lights and they are super bright. View attachment 214027
Are the pivots for the mirrors on the inside of the ROP's? We ride a lot of tight trails and if they hinge on the out side of the ROP's, I would tear them off first ride. We rub trees and all kinds of stuff. Can you use your lights ridding behind other riders? What brand? I like them!
Sheetmetalfab
Sheetmetalfab
2,227
14,032
Alaska
They pivot outside but also will spin on the rollbar when hitting hard.
B1CAA591 3DE5 4AD5 954B 04A242C34106
it was the only Aluminum clamp option I found that works well with the honda windshield.
i’ve bashed them on a lot of trees........
Reactions: PhilCod
208,730
Did yours come with the harness, relay and switch? I just got back from measuring clearance from ROP to windshield, I have 1/2 inch?
