Fishing rod holder
N
Nipper
84
136
Oklahoma
Any anglers got any good ideas for fishing pole holders? I was thinking about mounting a couple of these to the top of the hard top. Any thoughts? 0d87e04298f70aea8a4fd317978239fa
Sent from my SAMSUNG-SM-G930A using Tapatalk
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Any anglers got any good ideas for fishing pole holders? I was thinking about mounting a couple of these to the top of the hard top. Any thoughts?View attachment 44684
Those look like they would work. Bit if you wanted protection for the rods you could mount some 3-4 in PVC on upper rops cap one end threaded bushing on the other.
Diverguy
Diverguy
120
321
PA, USA
I was thinking about fabricating a crossbar with pvc (big enough for my rod butts) to attach to the center ROPS, and something across the rear ROPS for the rods to hang in securely. Protected from trees, etc., and easy access.
Reactions: Lady01
Great idea! Post a pic when complete. :cool:
Reactions: Lady01
Pmed489
Pmed489
119
137
if you use pvc capped on front then leave back open and make an angle cut where reel can lock in if spinning would have to look similar to a l cut slot
Reactions: Lady01
Diverguy
Diverguy
120
321
PA, USA
I started with 8 equal pieces of 1 1/4” pvc cut from a 5’ length
F4BE19A2 B308 4C8D A063 B2C316F5FC62
I set up my router table with a 3/4” cutter and used the fence and a stop to keep the cuts even
884D01E0 631B 46EA 9927 3DC6104A779B
I made them deep enough to hold the reel from swinging side to side while ridingA
75589E75 D19E 4FBF B781 2747A5EDD0CC
E1C323AD 487B 4AA3 AABD 621507D6BEDC
All 8 ready to go. I’m planning on using 1 1/2” aluminum angle from side to side mounted to a couple of rops clamps I bought on eBay. My rod tip holders are on the way from good old Amazon. Planning on hanging them the same way. My 700-4 is at my cabin right now, so I will complete this once I get it home for a proper fitting.
I started with 8 equal pieces of 1 1/4” pvc cut from a 5’ length View attachment 108353 I set up my router table with a 3/4” cutter and used the fence and a stop to keep the cuts evenView attachment 108354 I made them deep enough to hold the reel from swinging side to side while ridingAView attachment 108355 View attachment 108356 All 8 ready to go. I’m planning on using 1 1/2” aluminum angle from side to side mounted to a couple of rops clamps I bought on eBay. My rod tip holders are on the way from good old Amazon. Planning on hanging them the same way. My 700-4 is at my cabin right now, so I will complete this once I get it home for a proper fitting.
Good work brother!!!!! :cool:
Reactions: Lady01
hoghead76
hoghead76
1,213
6,708
oklahoma
like that set up like to see pic when you done
