This set up has little effect on front viability & quickly get used to having it there.
Found the box on line, measures 36L x 12-1/2 W x 6-1/2 H
Helps a lot with the storage problem these P500`s have.
I know some will have no use & some will not like it what counts is Works for my style o riding.
Open the Tip Out windshield , unlatch hood , slide hood INTO the cab for removal .( it's easy & it works )
The rear R.& Lt. attachment brackets are from ( Toyota Rav4 ) you have to remove them to put on trailer hitch.
They are only used to hold on transport trailer while in transit to dealer.
Locate & drill ONE hole trim a little plastic bolt on roll cage should use longer bolts.
The rest I fabricated with aluminum.
I broke one of the commandments putting toyota parts on a Honda oops well the tow vehicle is Toyota
The Harmony cover is Kayak storage port cover.
