BOX1
P500 Front bumper and winch mount
Tom_C
Tom_C
141
446
Virginia, USA
Hi All. New 500 owner. I wanted a 520 but there are none and the eta for anything is months off. I found a 2015 500 with 1500 miles and 250 hours, with winch, plow, hard top, wind shield, storage bags and a rear 2" receiver adapter for $8000, so I snapped it up.
It's in decent shape and runs fine. After looking at it after the purchase I see that the pervious owner took a lot of shortcuts mounting stuff. He cut the original bumper open to make room for the winch and did a home brew winch mount, and left some bolts loose, etc.
In short, not to my standards. I want to add the full front bumper and a solid winch mount.
Is it possible to get the full frontal bumper to replace the original bumper and a winch mount that will fit without modification? The winch is needed for the plow, which is a Warn 54" with the provantage front mount which is intact without damage or modification.
Reactions: KyGal83
Bigtee
Bigtee
556
1,213
Grayson, KY
I have a StrongMade bumper with winch and really like it.
6D613C46 ADAC 408E 9665 0AE4A170C3BB
Tom_C
Tom_C
141
446
Virginia, USA
Thanks for the quick replies. I was going to use the OEM front bumper, but will look at others.
(Won't buy from Amazon)
And this mount which looks like the KFI: Amazon.com: Dasen Winch Mount Plate kit - Compatible with 2015-2021 Honda Pioneer 500 Come with Complete Installation Instructions: Automotive
To confirm, any new bumper will replace the original bumper that the last guy chopped up, and winch mount will work?
Sheriff Chief POIDH Enforcement Officer
103,466
Welcome from Michigan!
awesome you were able to snatch one up at a good price! Hard tp do these days. Only one thing! The unwritten gospel around here cuz were imaginary deficient lol
PICS OR IT DIDNT HAPPEN!
Tom_C
Tom_C
141
446
Virginia, USA
Ha! I know I know. I don't have any new pics yet cause it needs a good wash and it's Hell in August here in VA right now. Here is a pic from the ad. You can see why it needs a wash.
500
103,466
Thats Awesome!
always loved the camo!
looks fairly stock. You got some spending to do! Hahaha
I had a yellow 15’ P5 was a fun hard working machine. I pulled 13 stumps with that bugger on my camp trail one weekend. Nice machine!
Tom_C
Tom_C
141
446
Virginia, USA
Yeah, looks pretty standard. It's got new Wanda tires (not sure if good or bad), a Warn 54" plow and Superwinch 3500, and he chopped up the front bumper to mount it. Not to my standards so that will get fixed immediately. I'll probably replace the winch cable with synth. Not sure what else I need, but the forum gods will tell me. :)
bowhunterbill
bowhunterbill
403
1,240
Bozeman, MT
Welcome from the ‘free state’ of Montana- and another camo P5 owner (2017). While blue (or red depending on who posts it) is the fastest- they can’t see us passing them. :)
There’s a ton of good info about bumpers/ mounting winches/ everything else already posted. Grab a cup of coffee tomorrow and search ‘bumper’, etc. and enjoy.
Also, read the reverse handle modification (you basically tighten a cable nut) to stop fumbling under the dash every time you want to put it in reverse.
Tom_C
Tom_C
141
446
Virginia, USA
Thanks. Will search for 'bumper' tomorrow. Just watched the vid on the reverse handle. Nice. I'm curious what it really does though. Does over adjusting that cable put in any stress on the trans or anything else?
Reactions: KyGal83 and Mudder
Bigtee
Bigtee
556
1,213
Grayson, KY
Does that replace the original bumper? The last guy cut a big slot out of mine and want to replace it or at least hide it completely. And, does this bumper come with the winch mount and cable slider thing included?
The StrongMade bolts on to the existing bumper and covers it. Depending on how yours is cut it might be the best fix. There’s a YouTube video on installing it, you could watch that and see if it will work for you.
Tom_C
Tom_C
141
446
Virginia, USA
Thanks. It looks like it won't cover up the mess in my bumper. Here's a pic. When I went to look at it he had the blade on, so it didn't jump out at me how he had mounted the winch. You can see he cut a chunk out of the top plate of the original bumper and make a home brew winch mount. All that stuff needs to come out.
I'm thinking I'll get the Honda full bumper and a KFI or similar winch mount and clean everything up... assuming that will all work together. Also going to replace the cable with synth and a bump stop.
Bumper
P
pappyo
586
2,326
I do not BUY I Build.
Pioneer P700 Bumper on -- 2015 RED P500 ( 1st. picture ) winch mount built in when fabricated to P500
2in. receiver Ft.& Rear on -- 2017 RED P500 ( 2nd picture )
2in. receiver Ft & Rear on -- 2018 RED P500 ( 3rd. picture )
Front 2in. Receiver All in ONE -- Vertical winch storage & Horizontal winch winch or Bumper use
Double 2in. Receiver on rear -- Top receiver winch use or Rear bumper -- lower 2in receiver towing or ???
In the works is 5000 lbs trailer tung Jack with adjustable 2x2 steel tubing to be Used in Any of the 2in receivers & in the 2in. Aluminum Channel of Ft. & Rear Bumpers seen in pictures.
Welcome to this ragtag group of Honda pioneer 500 owners & riders
A LOT of Good Info & B.S.to be had here & it's going to decrease your net worth.
RED IS THE FIRST COLOR ALL other colors followed Honda hopes they Sell
20210607 082430 20201114 111608 20200725 125103 20200725 122904
bowhunterbill
bowhunterbill
403
1,240
Bozeman, MT
Tell me more about the P700 bumper mounted on P500. Did you need to fabricate new brackets? Did a winch in the factory, lower position still fit?
Asking for a friend who has seem a P700 bumper on Craigslist for a couple months now.
11,203
82,759
Welcome, I have the Strongmade bumper which attached with U bolts to the OEM bumper tubes which you still have, just bolt it on with no mods needed. Extremely stout and mounted the winch on top. I have bumped trees and pushed over downed trees with no issues. The bulldozer of bumpers.
F7A5B0E3 9217 4D9C B312 E9CE7409FE3ECE54D019 1089 435A 8201 8082D69C7D5893761A06 DA5E 474D 8297 CD774B00247E
P
pappyo
586
2,326
Lower position fit?
Asking for a friend
Front bumper Bottom mounts P700 & P500 --"Identical" & Bolt right up.
When I did the redo on Top Bumper mounts - fabricated for top mount winch or -"2in. Receiver"- ( prefer top mount winch )
You & your friend are on your own -- on lower winch-mount -- Creativity will get it done
Reactions: KyGal83
bowhunterbill
bowhunterbill
403
1,240
Bozeman, MT
It’s not on Craigslist any more
34,173
  5. Talon x4
They couldn’t even wash it for their add pic……🙄
Tom_C
Tom_C
141
446
Virginia, USA
Yeah, it was pretty disgusting. Perhaps thats one reason it didn't sell, of course he was asking 10k for it which was a none starter. I sprayed a huge amount of dirt out of it, inside and out. No damage, but it had been buried.
Reactions: Montecresto
BOX2
box3
