Front differential oil leak
Elkhunter
Elkhunter
345
453
Minnesota
I noticed my front driver side differential is leaking out of the axel shaft. This is a new machine and I noticed it within putting on a 100 miles. Seems to me I have read This is a common thing. Has anyone else had this problem? Did having a new seal installed fix it?
Reactions: Smitty335 and TxDoc
5,488
25,260
Start here, post #17 -
Elkhunter
Elkhunter
345
453
Minnesota
Ok I checked the vent line at the differential the other day. I will check it going into the frame next. Thanks!
Hometeam
Hometeam
995
4,155
Normal, IL
I have noticed quite a few of guys with the leaking diff seal say that as long as it wasn't dripping out they kept going and had no issues with it. Some said it stopped seeping after another couple hundred miles. Sorry yours is leaking!(
5,488
25,260
Someone else mentioned that too, sometimes a seal has to seat and might leak 'a bit' until it does. 👍 My leak was insignificant but you risk ignoring it, thinking it's just a dribble and then it goes full retard and melts your differential - that was my biggest concern. :oops:
HUCK
HUCK
1,047
2,319
ARIZONA
Mine started weeping after 1k miles . Replaced under warranty , no leak since @ 5k . If it starts again and it is just a little like it was . I don't think I'll bother with it .
hondatalonr
38
53
Arizona
Friend here in AZ bought 100X from Nash. They told him at 100 mile service that there is a recall coming from Honda on the leak problem. They also told him they were ordering a new seal or seals for him to return later for installation and his is not even leaking? Maybe more dealer BS. My driver side seal has not started to leak again but have not put a lot miles on it. Another friend here with a 2019R has a driver side seal leaking. Don't know the miles. He had not seen it until I pointed it out. They don't seem to leak a lot, just messy. I would be tempted to just clean it and watch oil level for a while to see what happens.
Driesel15
7
21
add me to the leaky seals club. started dragging a tire tonight in the garage. no indication of problem emerging (noise, feel, drivability, sensor/code), while backing suddenly heard a tire squeal breaking feeling. Got out, skid mark on the concrete and passenger side will only rotate a 1/4 turn and its locked. Looked over the front end, driver side seal is leaking, will dig in tomorrow for more info. 2021 p1k5 1500 miles.
5,488
25,260
Talon or the Pioneer 1000 listed under your avatar? You’ll get more help from the P1K guys than the Talon guys If so.
TOGR
TOGR
81
406
53
NW Montana
  1. Talon R LV
Mine LF started seeping at a few hundred miles. Checked every couple hundred miles thereafter. At 3000 miles had probably added a total of about 6 ounces, so not that big of a deal, just messy.
At 3000 miles I also changed the oil in the differentials (used Napa synthetic). At almost 3300 now, the seeping seems to have stopped!
  • Wow
Reactions: Smitty335 and CID
hondabob
1,281
5,089
Prescott Valley, AZ
Both of my Talons have the d left front dif seal leakage. The improved 2021 seal didn't help on my 2020 Talon. I'm getting the improved 2022 seal installed and the leak at the boot clamp fixed on Saturday, it may help enough to satisfy me. I don't mine wiping it down occasionally. My 2019 also makes enough of a mess to have to do a big cleanup and add fluid. I will get it fixed next.
042
TerryH
TerryH
664
2,241
Springdale, Ar
I'll slightly modify a quote that an old friend used all the time...
"I got a front diff leak. You got a front diff leak. All God's children got a front diff leak." 😂
Mine has dribbled since 2019. I just check it every once in a while and add a few drops.
SLOWPOKE693
SLOWPOKE693
1,866
7,357
Somewhere in Texas
Has anyone tried drilling the vent hole in the diff larger and adding a fitting that will accept a bigger ID vent hose?
  • Wow
