P700 Fuse Box / Switch Panel / Accessory wiring
  • Thread starter 2018_700-Deluxe
  • Start date
2018_700-Deluxe
2018_700-Deluxe
Charlotte, North Carolina
First off, thanks to the members that were able to answer my sub-harness question...greatly appreciated!
So, i've been doing my research, both in these forums and online in general, trying to figure out the best way to wire up my 12v add-ons. Can somebody please take a look at my diagram, to see if everything looks correct? Unfortunately, I know just enough about electrical wiring to be dangerous :eek:
In the diagram, the wires aren't aren't crossing...I just didn't have enough room to fit it all on one page (hence, the different colors)
NOTE 1: I already added a winch. Due to the potential amp draw, i'm leaving it off of this fuse panel. It's connected directly to the battery with a 150A circuit breaker.
NOTE 2: I will eventually add a second battery, once I figure out where I want it and I can fabricate a mount/holder for it
(this forum is a wealth of knowledge...not sure what i'd do without it!
  • P700 wiring (manual wire lines).pdf
2018_700-Deluxe
2018_700-Deluxe
BUMP...trying to get this wired up before the weekend, so I can enjoy the snow they are forecasting for the CLT area. Thank you in advance!
Neohio
Neohio
Beast of the East
17,682
85,239
Painesville Ohio
Does the switch panel come pre-wired from factory?
I am going to ramble a bit here. Stay with me.
FP (fuse panel) SP (switch panel)
You have one lead from FP to SP to supply power to VM/dual USB/12v plug.
Personally, I would extend that power to supply power to the lower LEDS of the switch panel, so anytime you turn your ignition on, activating the circuit breaker, all lower lights will illuminate.
One benefit to how you currently have it wired, if you blow a fuse for the light bar, pods light or speaker, the lower LED of the switch will not iilluminate, kind of giving you a heads up if 1 of 6 switchs is not on.
The circuit breaker does not have a ground. one lug is power from battery, other lug will go to your 100a relay.
Have a dedicated ground from battery to FP. use one of the little ground terminals from FP to 100a relay.
