P1000 Glossy black wire protector
misterkit
42
36
ny
One of you guys probably know....What is the glossy black tube called that I see in a lot of engine compartments or that protects multiple strands of wire in places like light bars? I can see it installed already in my p1000 but don't know what it's called or where I can find it. This is similar to split wire loom but its thinner and without the split.
L
LarryAmboy
902
2,000
Castalian Springs, Tennessee
Like this?
E27549e59cd8eeed74dea02f059e0c21
Heat shrink?
sharp
sharp
3,757
14,955
Tennessee
Nope.
It reminds me of electrical tape. Except in a tube/conduit form. Thin wall, smooth, and no split like the spiral wrap or wire loom stuff.
Rubber wire sleeve. You can get it at lowes. Google rubber wire sleeve.
Reactions: Deluxe700
misterkit
42
36
ny
Ok I found an example of it on this site. If you look at the pinned lighting thread at the top of this forum you can see the jacket/protector coming off the brown wire illumination picture:
IMG 6641
misterkit
42
36
ny
On my 2017 it's a shinier than the pic above. Here is another example. I don't think it's wire shrink unless they forgot to heat up. Most of the time the cables are loose in the jacket.
20170905 203044
misterkit
42
36
ny
I should have more clear. It's the tube that is wrapping all of the wires to the connector with the brown wire.
Reactions: sharp
Doogy
23
22
North Carolina
Looks like heat shrink. You can use larger heat shrink and it will only shrink down to a certain size. That will leave the wires loose if you use a larger size.
Reactions: sharp
