P500 Glove box hinge replacement
Chooglin
Any of you guys/girls that bought one of the original 15 glove boxes that I made and sold (the ones with the s***ty hinges) and will be at the Takeover , if you would like a replacement hinge that I use on them now , let me know. I will bring them with me (free of charge) but you will need to get them welded on to the box !
Anyone not going to Takeover and would like a replacement hinge , PM me you're address and I will send you a new hinge.
These are only the first 15 boxes that I sold in 2016 some time around April and May.
Reactions: jinx and trigger
NTCPrezJB
NTCPrezJB
President of #NTC
99,804
892,438
Canton, OH
I just wanted to say kudo's for this. If I do a glove box it will definitely just be a purchase from you just because of this post! A tip of the hat to you sir. :)
Reactions: rocmar and Chooglin
155,150
I have one of the first 15 and it hasn't failed yet, I'm good. ;)
Glove box
155,150
Yes, a Garmin Montana 610. It's in a RAM mount that is hard wired so I don't have to worry about it being charged. Has a set screw as well so it doesn't get stolen. The T Bar was purchased from Jak, don't think he makes them anymore. Goes through dash and is bolted through brackets that sandwich the frame.
Reactions: SXSHP500CO
SXSHP500CO
SXSHP500CO
Pounding - Beaver
232
331
Northglenn Colorado
Can you send me a picture of your dashboard please? My key five is pretty much a virgin on the dashboard except for my lightbar thanks
Chooglin
Mine was one of them.Still works good though.Little lose.Ill be at takover and you can check it out.Thanks
I will bring you one anyhow , if you want to install it fine , if not , just keep it!
Reactions: markie
155,150
It's a little loose when you open it but the only way I'd change it out is if it broke. Even added extra weight to the door and I've seen no indication that it's going to fail.
Forget that welding and grinding sh**, if it does break just give me one of those new ones for half price or something. :D
Chooglin
I'm bringing one for you too , just in case you need it some day :)
Reactions: trigger
