popeye
Has any one put a hand powered wiper through their plastic winsheilds? Found one on amazon by emp im contemplating buying
Thats the emp wiper on yours? If theblade is crappy would changing it out to a better brand name one from the parts store help. After not being able to see inthe snow last weekend i gotta do something. Plus i havnt been able to ride it around town because its always sprinkling here in western washingtonWorks great! Blade is crappy though. View attachment 28906
Because they seemto be short or small i was thinking 2 might be needed. And mount it up high like cp did. I have r he factory split plastic if you think it might make a differenceI think there has been a few guys run them and I'm sure they are alot better then an old towel. (That's what I use) I like CP's location, but I have seen some mounted on the bottom. If you end up doing this, let us know how it turns out.
I got one of those magnetic ones and it didn't work very well. When i ran mine in snow there was a lot of steam from the engine and I got more fogging and frost on the inside than the outside.
I can deal with the steam on the inside a lot easier. I found just cracking the split windshield 3/8" gave just enough flow to keep the inside heat from the windsheild. And the fog was gone. Also had some old anti fog spray on it that i had pulled out from our ski gearI got one of those magnetic ones and it didn't work very well. When i ran mine in snow there was a lot of steam from the engine and I got more fogging and frost on the inside than the outside.
I should've mentioned that it's glass. And I wouldn't crank down pressure on the wiper blade on plastic as that would probably scratch the windshieldCP is your windshield plastic or glass?
