P1000 Heat shielding under rear seats
sugarray
sugarray
Is this a game show?
661
1,257
WV
My daughter and MIL really c/o the heat from I between the seats in the rear this past weekend. I have a full shield, like Jackal, under the front seat. Stopped the steam, but shifted the heat and steam out the latch hole between the seats.
Any thoughts on how to fix this? The problem I see is the bed latches underneath and the seat latches above. Just doesn't seem to be anywhere to shield without leaving a big hole.
I will put a fan on at some point, but would like some shielding as well
sugarray
sugarray
661
1,257
WV
Here's what I came up with. Wife is going to sew heat shielding between this folded rug. We'll then put it over the latch hole and center support.
Reactions: pct
My single 4" fan completely stopped the heat rising up between the seat and bed. You will be happy after you install the fan.
I noticed that because I usually rest my arm over the back of the seat and immediately noticed that when the fan is running, no heat. If I turn off the fan, the heat rises up.
I guess the fan is strong enough to blow the heat out the back vs the heat rising.
sugarray
sugarray
661
1,257
WV
Thanks for that info Joe. Just ordered my fan, wire, snorkel supplies, but forgot switch. I might just get a 12 volt plug in until I get the rest of lights and switch panel.
Reactions: joeymt33
270,792
The fan is the way to go, it blows the heat back and away instead of radiating straight up to the passengers front or back seat.
Reactions: cwalton
Jbird
Jbird
392
475
Mena, AR
Will still install the fan before next summer but we did find one quick fix that helps.
We took a length of 2 1/2" diameter armaflex (foam tube sold to insulate water pipes) and stuffed it into the space between front seats and the upright panel with the metal bars on top.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Would you mind sharing a picture?
Eltobgi
Eltobgi
4,599
15,186
North Dakota
After hearing about the Honda Fix for the heat problem and seeing their weatherstrip that went across the back of the seat I considered doing the same thing with a pool float noodle/toy similar to what you used that I had lying around the garage! If I can use something that is lying around the garage to solve a problem it is so much more satisfying!:)
ToddACimer
ToddACimer
Pioneer 1005-2
3,659
15,383
Oshkosh, Wi
I added a heat sheild under my rear passenger foot wells and on the engine cover no-step panel
IMG 20170917 162700618 HDR
