P700 Help from those of that had a plugged muffler
ByronM
ByronM
175
353
St Charles, Il
how was it diagnosed.
My 700 has less then 1000mi on it , I was running it down a road at 35mph and it started losing power, when it dropped down to 25 or so I stopped and the engine stalled, started rightip and seemed fine for a couple of miles. I shut it off and restarted it and it seemed fine again so I ran it back to the trailer, next morning ran it about 10mi or so and it seems fine.
I pulled the end piece/spark arrestor off and looked inside the muffler, every thing looked fine, smacked the muffler a few times but did not hear a rattle.
William
William
1,442
2,887
Flowood MS
Could it be the spark arrestor?
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Plugged muffler is rare I would think. I don’t know I have never had a issue. I know you need to clean spark arrester some. And take the plug out and blow out any carbon sometimes. But plugged enough to cause engine problems i don’t know.
Reactions: Mudwing
ByronM
ByronM
175
353
St Charles, Il
The spark arrestor was clear. The reason I am asking about the muffler was several years ago there were some mufflers that had a internal baffle weld fail and block the exhaust, the fix was replace the muffler.
I just don't know if you could see it inside the muffler by pulling,the spark arrestor.
William
William
1,442
2,887
Flowood MS
I think some pioneer 500s had that problem.
swsebek
swsebek
2,854
5,835
pa
this was mainly on the 2014 models andwhen you took the end of the pipe off you could see it had come off in there.....
not sure your year but check air filter and check to see if you have water in gas...or maybe e-brake lever stuck on
ByronM
ByronM
175
353
St Charles, Il
Sorry its a 2017, it was serviced last fall, oil and filter, valve adjustment, air cleaner and fuel stabilized. Rode it about 350 mi last week on the Hatfield McCoy trails, fuel used was from a busy station in town.
(Gilbert) Used the sa,e fuel in my truck.
I agree that the muffler problem seemed to be earlier models but the symptoms are similar so I wanted to make sure that I could spot the problem with an inspection.
I will start checking grounds, plugs and look inside my tank.
Thanks all for the ideas.
