P1000 Hitch Receiver Extension
Jbird
Jbird
392
475
Mena, AR
Are you using an extension in your receiver hitch to get clearance so your trailer does not contact the muffler shield? If so, which one did you get? I can't find a regular insert long enough to get the ball back far enough.
Drill another hole in my bar so that it will stick out a little bit further.
6206d42247b435416a5da1756c227c6a
322,675
Do as Joey did if problems. If you add an extension you'll drastically reduce capacity and place lots of additional stress on the factory steel it's thin back there. Only a 150 rating of downward weight
Reactions: Jbird and joeymt33
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Heininger 6000 Advantage Adjustable 11-Inch Hitch Extension
4.5 out of 5 stars 151Reviews
  1. 31VTVmOD12BL SY400
  2. 412Qqhlp pL SY400
  3. 41QvysYRBcL SY400
  4. 61YNNZILw9L SY400
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
The description says to be used for a bike rack only which lines up with what CP says about it being too weak for much tongue weight.
I been using it for 6 months its made out of thick steel.
IMG 20160523 170726880
with no problems
Reactions: Nipper
dojo
dojo
26
26
New England
was just looking into this, and Joey has the right solution I think. Otherwise were creating a big lever that's going to apply more pressure than desired.
guess its finally time to buy a real drill press
