P1000 Honda accessories
L
Lapcinski
50
136
Minnesota
  2. Do not currently own
Here’s some pictures of what Honda accessories look like (dealer installed) in a new 2021 Pioneer 1000-5D. I added these upgrades from the dealer before I found this website, since reading I probably would have done some things different.
5445111C DC4B 451D AFE1 9A56F952E72A 744CCD44 7B7A 44BC 9C5C 60498F1003F3 3AFBF942 4B22 44CD A7FE DB2DD603F772 6EC94B70 3DD3 4287 A866 74E8AF67DB1A 8C54E979 82C0 4E28 BB8D 0C30FF5BC2BD 95C5E7E3 FD67 4792 A175 1B0DC65DFAD1 3A89E0D7 9976 46BF BDC2 2A49CCB2465D 1D17F7A0 F3FC 4BAE B071 44FD64EBF20E 0E94205D 7E43 44E2 8F05 32B172EFFED9 1129ADC4 68DA 4F0D 92CC B1B35629A90F A7D4BCE6 D30E 4230 A551 CD61C1A068D3 0D98F3E5 50E5 462A 891B 68BE1B2A9ED0 35059E1A 34C2 4493 B452 15DF4841C6C2
Papaandhistoys
Papaandhistoys
134
227
Backwoods of northern Michigan
View attachment 238124 View attachment 238125 View attachment 238126 View attachment 238127 View attachment 238128 View attachment 238129 View attachment 238130 View attachment 238131 View attachment 238132 View attachment 238133 View attachment 238134 View attachment 238135 View attachment 238136
I’d really like to see a side view of your rig
Reactions: Biteme and ChadD
HondaTech
Not to stir up anything, but that is not where the heater vents go if installing the Honda heater, nor is that the switch for their heater.
L
Lapcinski
50
136
Minnesota
That’s really nice! I do like the hard door kit! Is the fit pretty good?
Yeah, I think so. The hard cab really is put together pretty well for panels. Window and back panels are nice. There is a couple of small openings around the windshield rubber seal and the dash. I’ll find some type of rubber seal to make it more air type. BIGGEST problem I found on my brief ride last night are the shifters. Lots of air. I’m going to find a couple boots to put over them!
TxDoc
TxDoc
1,609
5,581
TEXAS 🇨🇱
photos.app.goo.gl
If you have air coming in the shifter gates...
Rad Customs may have your solution. He's running a batch in December
dougclind
dougclind
26
62
Roan Mountain, TN
Hey Honda tech, (and anyone else!) maybe you can help me out. I have a 2020 P1K5 LE and I had the dealer install the Honda light bar and hard top. That entailed installing their switch panel on the dash and an additional fuse box under the hood. That fuse box has spots (and fuses) to plug in another light bar (and a heater and wipers.)
So I want to add a rear facing light bar (and maybe some other lights) so it makes sense to try to use what I've already paid for, i.e. the switch panel and fuse box. BUT the connector sockets on the fuse box are a mystery to me. Some kind of molex connector or something like that. Do you know if I can get those somewhere? The unused ones are 2, 3, and 4 pin sockets and they're keyed such that the two on either end have a flat spot, so you can't plug it in wrong.
I'm including a pictureI took with my phone in case people have trouble with my description. If I can't get the right plugs I don't even see any good way I could jury rig it other than unsoldering the sockets from the board (I can do that) and replacing them with wires to a socket I CAN use but that would really be a pain.
PioneerAuxFuseBoard
PioneerAuxFuseBoard
Reactions: TxDoc
L
Lapcinski
50
136
Minnesota
View attachment 240639View attachment 240639
I have the same the setup. Check this out. The product was great. The seller even better! You could also make your own with the molex connectors. That would be cheaper, but this was easier.
Reactions: TripleB and TxDoc
dougclind
dougclind
26
62
Roan Mountain, TN
That's actually not what I need because I already have that. A harness with a plug came with the switch panel but that goes to the switch panel. What I need is something to go to the light bar. I can't plug into the fuse panel without the right 2 pin plug.
Reactions: esandy
L
Lapcinski
50
136
Minnesota
if you have the OEM switch plate and fuse box, this is what you need. The switch plugs in to the switch plate and the wire plug into the fuse box out to your light! FYI. Since I have a heater and Honda didn’t use the OEM fuse, I used the 10 amp (3 plug)for my light bar but had to up the fuse to a 15 amp, because it burnt out my 10! My light bar was rated at 240 watts. I probably should be using a 20amp but the 15 has been been working.
dougclind
dougclind
26
62
Roan Mountain, TN
Ok, I see what you're saying, I think. But those harnesses have 3 and 4 pin plugs so they would go into the heater and wiper spots on the fuse board. I'm reluctant to do that because I might add those in the future so I want to leave those open. But following your lead, I did find this harness
It doesn't list the length so I could buy it and send it back if it isn't long enough. I would sure rather find just a plug and make up my own cable.
L
Lapcinski
50
136
Minnesota
Gotcha! Have you gone to the Molex site?
