Talon Honda Accessory Particle Seperator
HondaTech
Just got the accessory bulletin this morning, it appears it's a S&B manufactured piece.
Sorry for the screenshot couldn't figure out how to upload a modified pdf with pricing and sensitive info blocked.
Screenshot 20190924 105532 Drive
906UP
906UP
12,969
120,787
da Yoop
Beats throwin a $50 air filter in your Talon every 100 miles.
Any idea when it'll be available? I did a search but haven't found any info on it yet.
Morris1219
52
24
Dallas TX
I know on my can-am I love this, definitely will be ordering for talon.
The only thing is with full front and back window can you just turn this around to point to back and it will just pull the air in with fans?
906UP
906UP
12,969
120,787
da Yoop
The screenshot says it can be mounted high on the ROPS, I assume this would be for forward facing above the roof
Reactions: CumminsPusher
Morris1219
52
24
Dallas TX
That’s what I was thinking, for trails that won’t work for me. Some trees hang low lol
HondaTech
Will not work with Honda rear panels.
hondabob
1,158
4,522
Prescott Valley, AZ
The high mount may work with the rear window but its going to take a lot of window cutting to fit around the particle separator. If someone will do it and make a cut out template it will help a lot. Its not so difficult for a 3 inch tube.
20190916 114715 resized
Reactions: TripleB
906UP
906UP
12,969
120,787
da Yoop
Any word yet how it will attached to Jackson's turbo kit?
Shouldn't be any different unless the turbo kit doesnt retain the factory airbox..... just a guess o_O
PaulF
PaulF
1,462
4,810
The turbo completely replaces and relocates the factory air cleaner (the intercooler is located where the air cleaner is now) so i doubt it will be a direct fit. Since the turbo is Honda approved, I would not be surprised if there is a turbo retrofit kit/adapter that will be available for the S&B.
It is VERY different than stock. The factory air cleaner box is removed and the intercooler is in its location. Go to about 5:15 in this vid...
The air filter is a canister type about 7 to 8 inches in diameter and about 16 to 18 inches long. The inlet appears to be about 4 inches in diameter. Go to 7:50 in this vid...
Reactions: 906UP
906UP
906UP
12,969
120,787
da Yoop
Good catch but watching those vids makes me want a turbo o_O
DuneFlyer
25
40
Lake Havasu, AZ
I called Jackson today and asked about the S&B connection, when the turbo kit will be available, and if they are going to have a turbo Talon at Glamis on TG weekend - Honda is doing demo rides at Glamis the weekend of Nov 28, 29 & 30.
No way to connect an S&B with the Jackson turbo - they are considering it.The big K&N they use will be OK for the dunes IMHO but I'm a little wary how it will do on our dusty hardpack trails here in the West.
Turbo kit will be available Oct or Nov.
They did not know if they were going to Glamis on TG weekend and doubted that there would be a turbo Talon there if they did not go.
I'll call them back in a month - I hope they know more then.
