P500 Honda OEM Hardcoat Windshield: OEM Lower Seal?
U
uconn411
160
255
CT
So I wanted the OEM seal that I lost somehow when trailering. I ordered 0SR73-HL5-100R2, Windscreen Trim Kit. But this appears to be for a 1000. Anyone know the correct part number for the P500? Thx.
105,594
Seems to be more of an accessory item part. Even though it's made by Honda, It doesn't appear to be list on a normal parts list for the machines themselves.
Mudder
Mudder
NTC Ambassador of Walls
11,690
88,472
Some replacement gasket sources in thread. P500 - Windshield Gaskets
Search Results
4D718DAE 21A8 4B30 A8E8 1C910D9A42AE
Reactions: HP5NC and 100Acre
U
uconn411
160
255
CT
Honda got back to me and said the exact same part number I mentioned in the 1st Post is the correct one. I sent them back a response that it cannot be and showed this this pic of the lower seal mounted to my windshield. I’m waiting for their response. While I could cut the seal to fit the windshield, it is way too thick and won’t allow it to close properly.
. 45b6a4ba1193c5ef5e68408bebd3acc1
Reactions: Vaden01
Vaden01
Vaden01
126
299
Callahan, FL.
Cut iff off to length and it will work fine. I had to cut mine as it came with windshied.
Reactions: trigger
Vaden01
Vaden01
126
299
Callahan, FL.
You can basically go to automotive junkyard and grab a body side door weatherstrip off most cars and cut it to length also. Same type of seal.
Reactions: Gassygordo
U
uconn411
160
255
CT
It’s odd to me that the windshield when I bought it New came with all the weatherstripping of the correct size, that’s why I was questioning cutting it. Seems a lot thicker too, I’m hoping to be able to close my windshield fully. Will give it a try once this heat wave passes...
Reactions: Vaden01
