P1000 Honda OEM Winch
hibbert
65
81
CR
Hey,
So I've come to the realisation that I shouldn't have cheaped out and should have a winch.
During my research though, I dont see many people using or recommending the Honda OEM winch? Why is that?
That would be my easiest choice because the dealer could do everything, but I just don't see people raving about them.
Plus the oem winch and kit costs $1,300 from the dealer here so if I'm spending good money, it has to be on good product and I can always import any winch I want for a lot cheaper.
Thanks for your insights!
Reactions: TripleB
allgm1
allgm1
1,049
1,484
New Hampshire
I think the guys with excessive cash or lack of knowledge to install go with the honda stuff. I believe honda uses warn winches, which are very good quality winches. But for us with less money to burn and the knowledge to install take a less expensive route and gather the parts we want and do it ourselves to save a few bucks for other items.There are a lot of options out there for winches and winch mounts that are just as good as the honda set up, basically comes down to how much you want to do your own install.
Reactions: CMB and hibbert
hibbert
65
81
CR
Yes good advice - I am a "buy things once" type of person so I would rather spend a bit more on quality.
Looking at the install instructions for the OEM kit looks overwhelming, possibly beyond my ability and it doesnt seem you get a nice little rocker switch or wireless capabilities which if I'm spending the money - seems like I want.
Lots of people recommend the Warn 4500 winches but NOT the Honda OEM which is also Warn - I assume because of cost?
Ultimately though I want to have a rocker switch in the cab and wireless just in case and I'll attempt the install because it seems like a great way to learn about the machine and if it goes wrong I'll find someone more capable.
Is there a winch that is easy to install with the rocker switch and wireless included?
bluemountainbugler
bluemountainbugler
45
149
Walla Walla Wa
I agree that a winch is essential. I went with the Warn setup because of my experience with them on other rigs. I negotiated a final price including the winch, windshield and roof at time of purchase and was able to save a lot. If you have the knowledge to install the labor is always a way to save big.
There are a huge selection of quality winches out there but there is a lot of junk too. I would make sure to research the options and this forum is a great place to hear what others have had good experience with.
Reactions: Mudwing
hibbert
65
81
CR
Yes I've been looking through lots of options, as well as the Warn - it seems the wide KFI Stealth is held in high regard and includes lots of bells and whistles - SE45w-R2 KFI Stealth Winch - KFI ATV Winch, Mounts and Accessories
I can just go to the dealer and have them install the OEM winch and kit - but I'm in Costa Rica so it's $1300 installed which is the easy option.
Or I can buy something else, install it myself (or have the dealer install) and import it for roughly whatever the base price is plus 30%
JenElio
JenElio
71,196
652,587
Loxahatchee, florida
I'm not expert but I would say if you want to attempt the install your self you could probably save around $500 and end up with a really good winch (warn, etc.) The install is really not that complicated, the hardest part honestly is probably choosing the location of relays, switches and such. My 2 cents
Good luck
And don't forget.......pics or it didn't happen!!
Gabbas
Gabbas
280
701
Humboldt, Iowa
In my experience and research, the Viper winches, like the ones offered through the forum store are a very good winch. I have the 5k lb Viper Max with a dash switch also a wired plug in remote that I can use. It was easy to install and took about 4 hours. Just read directions that are made specific for our machine. I am one of those people that would rather do the work my self and take the time than pay a dealer way too much to do it. That way when something happens I will know how everything is installed.
Sent from my Pixel 4 using Tapatalk
bluemountainbugler
bluemountainbugler
45
149
Walla Walla Wa
Just FYI the Honda OEM is the Warn 4500. No difference. Just what the dealer sells just like the Honda snow plow is Warn also. Can't speak to the KFI winch but I just purchased the KFI plow and it is very well built. You can get the Warn winch and mount at other outlets besides the dealer. My dealer wanted 700 for the install of mount and winch. Most installs have good instruction and support plus youtube videos can be a great resource at times.
Russ989
Russ989
22,639
147,230
G
Hey,
Go to the club store, buy a Viper winch and call it a day. The OEM isn’t going to be any easier in the end. That’s just my two cents.
Russ989
Russ989
22,639
147,230
I have a 4500 Viper Elite and it’s been through some hard pulls. Zero issues, great winch. I had 4500 Viper Max on my 700-4, zero issues as well.
hibbert
65
81
CR
Thanks for all your advice!
I guess the hardest part of the install really is splicing into power and then cutting a hole for the swtiches.
The KFI SE45w-R2 looks like it just wires direct to the battery though-
2020 11 29 08 27 17
Is there any downside to wiring direct to the battery and not via the 15a Acc Fuse?
I only have 1 battery but no other accessories beside a motion sensing motorcycle alarm.
Reactions: Russ989
hibbert
65
81
CR
G
How did you take care of power?
Reactions: Russ989
Russ989
Russ989
22,639
147,230
Most winches wire up this way, it will be fine.
Russ989
Russ989
22,639
147,230
Gabbas
Gabbas
280
701
Humboldt, Iowa
I suggest doing a dual battery setup. That way you will have a battery that specifically powers your accessories. Your clutch system is dependent upon battery voltage to work properly. My winch is wired just like the diagram you showed.
hibbert
65
81
CR
Mine is powered from the battery.
Viper Elite 4500 Winch Install
Thanks for the video, seems straight forward except that video make the power bit look terrifying haha
hibbert
65
81
CR
Thanks - I won't be running other accessories except a motorbike alarm (with 9v battery) and the winch so you think dual battery is required?
Gabbas
Gabbas
280
701
Humboldt, Iowa
100% yes. It's cheap insurance vs replacing clutches.
Russ989
Russ989
22,639
147,230
If you’re not doing a lot of winching, I’d say no. The Pioneer 1000 has pretty good output for the electrical system. If adding radios, lights and other accessories then you need to add the extra battery.
HondaTech
Just an FYI for anyone looking into getting the OEM solution.
Honda is moving to the new Warn VRX winch here soon and discontinuing the old Advantage.
