P1000 HONDA PIONEER 1000 3P/5P, ACC OR BACKUP LIGHT WIRING HARNESS, 6 FT, PLUG & PLAY
STRATOSMICRO
STRATOSMICRO
37
22
49221
  2. Other Brand
Backup Light Harness for the Pioneer 1000, no mods necessary.
Welcome to Honda Pioneer Tech
This harness will only provide power when vehicle is shifted in reverse, it functions off a triggered ground that is only present when vehicle is put into reverse gear.
  • To install, simply remove factory filler plug (located on drivers side rear of engine) by gently lifting retaining tab to remove plug from connector, then install our custom harness.
  • Harness is constructed with tough 18 AWG wire, approximately 6 foot in length, sheathed with flexible PVC tubing that is gas and oil resistant.
  • Harness Plug is a 2 Position Plug that will only fit connector located at rear of engine near oil filter housings.
  • Water resistant gaskets are installed on connections
  • Pig tail for device is included
  • This harness will support a 5 AMP, 60 Watt device
  • Each harness is hand built and tested in the U.S.
eBay Store link: HONDA PIONEER 1000 3P/5P, ACC OR BACKUP LIGHT WIRING HARNESS, 6 FT, PLUG & PLAY | eBay
P1000 bu
b_king1
24
14
Virginia
I have a 18 P 1000-5 and I used my test light on the 2 prong black plug on the driver's side just at rear of the engine and it has no power. I tried with the switch on. switch on in reverse and even tried it with the switch on with the lights on anyone have an idea what's going on?
Reactions: sharp
STRATOSMICRO
STRATOSMICRO
37
22
49221
  2. Other Brand
It sounds like you are on the wrong plug if you are trying for the backup 12v power. it should look like this I believe
Swampmonkey
Swampmonkey
149
149
Al
Can you make these with two male ends? I have a Rigid srm Pro diffused back up light ordered and from what I can tell it has a prewired female plug. And can I get a harness thru PayPal? Not a fan of eBay.
Reactions: sharp
STRATOSMICRO
STRATOSMICRO
37
22
49221
  2. Other Brand
We provide a male pigtail that will plug directly into the female end of the harness for serviceability, yes we can do Paypal, call our store @ 517-264-5101 for details and ask for Rob.
Thanks, Stratos
Reactions: sharp
L
Lorraine
Richton, MS
Can you recommend a back up light that this harness will plug directly into?
G
gborgstede
Mandeville, LA
Is the connector plug for the reverse light wire harness the same connector plug for a turn signal plug and play wire harness or is there two different connector plugs for each wire harness?
