P1000m5 HONDA PIONEER 1000 3P/5P, LED LIGHT BAR WIRING HARNESS & SWITCH KIT,6 FT, 7.5AMP
STRATOSMICRO
STRATOSMICRO
37
22
49221
  2. Other Brand
Requirements: Honda Signature Accessory SWITCH PLATE/VOLT METER/WIRE HARNESS
0SA30-HL4-100
Welcome to Honda Pioneer Tech
KIT#08 950-HP1A-AA-LB75-160604, 7.5A LIGHT BAR SWITCH & HARNESS KIT. CONSISTS OF: 7.5A LIGHT BAR SWITCH, 16AWG 06' HARNESS WITH 4 POSITION PLUG, 11" ZIP TIES-QTY 3. APPLICATION: PIONEER 1000 3P/5P ALL YEARS. LIGHT MOUNTING LOCATION: FRONT BRUSH GUARD. KIT DOES NOT CONTAIN LIGHT BAR.
    • Requirements: Honda Signature Accessory SWITCH PLATE/VOLT METER/WIRE HARNESS must be installed in SXS before proceeding.
    • Harness is constructed with tough 16AWG wire, 6 foot in length, sheathed with flexible PVC tubing that is gas and oil resistant.
    • Harness Plug is a 4 Position Plug that will only fit "WIPER" 7.5 AMP connector in Accessory Fuse Box.
    • Harness Plug has splash proof gaskets installed on the base & plug
    • This is a 7.5 AMP rated harness that will support a 90 Watt device
    • Led Light Bar switch is a Heavy Duty, 20 AMP, non-lit rocker that will plug directly into the Honda Switch Plate Accessory Harness.
    • Each harness is hand built and tested in the U.S.
    • Contains 11" zip ties, Qty. 3
    • Instruction sheet is included with kit
    • LIGHT BAR IS NOT INCLUDED
P1k 75a led lb
