P1000m3 HONDA PIONEER 1000 3P, REAR WORK LIGHT WIRING HARNESS & SWITCH KIT, 14 FT, 5 AMP
STRATOSMICRO
STRATOSMICRO
37
22
49221
  2. Other Brand
Requirements: Honda Signature Accessory SWITCH PLATE/VOLT METER/WIRE HARNESS
0SA30-HL4-100
Welcome to Honda Pioneer Tech
KIT#01 950-HP13-AA-WL05-161402, 5A REAR WORK LIGHT SWITCH & HARNESS KIT. CONSISTS OF: 5A WORK LIGHT SWITCH, 16AWG 14' HARNESS WITH 2 POSITION PLUG, 11" ZIP TIES-QTY 6. APPLICATION: PIONEER 1000 3P ALL YEARS. LIGHT MOUNTING LOCATION: REAR ROLL BAR. KIT DOES NOT CONTAIN WORK LIGHT.
    • Requirements: Honda Signature Accessory SWITCH PLATE/VOLT METER/WIRE HARNESS must be installed in SXS before proceeding.
    • Harness is constructed with tough 16 AWG wire, 14 foot in length, sheathed with flexible PVC tubing that is gas and oil resistant.
    • Harness Plug is a 2 Position Plug that will only fit either “AUX LIGHT” or “LIGHT BAR” 5 AMP plug in Accessory Fuse Box.
    • Harness Plug has splash proof gaskets installed on the base & plug
    • This is a 5 AMP rated harness that will support a 60 Watt device
    • Led work light switch is a Heavy Duty, 20 AMP, non-lit rocker that will plug directly into the Honda Switch Plate Accessory Harness.
    • Each harness is hand built and tested in the U.S.
    • Contains 11" zip ties, Qty. 6
    • Instruction sheet is included with kit
    • WORK LIGHT IS NOT INCLUDED
    P1k 3p rear work light
