P700 HONDA PIONEER 700 2P / 4P, DOME LIGHT WIRING HARNESS & SWITCH KIT, 14 FT, 5 AMP
STRATOSMICRO
STRATOSMICRO
37
22
49221
  2. Other Brand
For use with:
Honda 0SA30-HL3-100 Switch Plate/Volt Meter/Wire Harness
Welcome to Honda Pioneer Tech
KIT#29 951-HP700-DL05-161402, 5A DOME LIGHT SWITCH & HARNESS KIT. CONSISTS OF: 5A DOME LIGHT SWITCH, 16AWG 14' HARNESS WITH 2 POSITION PLUG, 11" ZIP TIES-QTY 6. APPLICATION: PIONEER 700 2P/4P ALL YEARS. LIGHT MOUNTING LOCATION: ROLL BAR BEHIND FRONT SEAT. KIT DOES NOT CONTAIN DOME LIGHT.
  • Requirements: Honda Signature Accessory SWITCH PLATE/VOLT METER/WIRE HARNESS must be installed in SXS before proceeding.
  • Harness is constructed with tough 16 AWG wire, 14 foot in length, sheathed with flexible PVC tubing that is gas and oil resistant.
  • Harness Plug is a 2 Position Plug that will only fit either "AUX LIGHT" or "LIGHT BAR" 5 AMP plug in Accessory Fuse Box.
  • Harness Plug has splash proof gaskets installed on the base & plug
  • This is a 5 AMP rated harness that will support a 60 Watt device
  • Dome light switch is a Heavy Duty, 20 AMP, non-lit rocker that will plug directly into the Honda Switch Plate Accessory Harness.
  • Each harness is hand built and tested in the U.S.
  • Contains 11" zip ties, Qty. 6
  • Instruction sheet is included with kit
  • DOME LIGHT IS NOT INCLUDED
HONDA PIONEER 700 2P / 4P, DOME LIGHT WIRING HARNESS & SWITCH KIT, 14 FT, 5 AMP | eBay
P1k dome light
