P1000 How do you bleed the brakes on a Pioneer 1000 LE?
SuperDutyJohn
SuperDutyJohn
254
437
Vero Beach, FL
As described above, I've lifted my new 2018 Pioneer LE with portals and 30" tires. I'm having trouble getting the air out of the brake system using standard brake bleeding techniques, I'm worried the 4x4 system won't work as advertised in respect to the LE 4x4 system. Any suggestions?
Reactions: sharp
Should be the same as far as bleeding the brakes.. start at the furthest from the MC and work your way around as someone pumps and holds the brakes while you let off the bleeder. The LE works off an ecm
Tramguage1
Tramguage1
Texan
7,379
29,702
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I had a couple buddies help me swap on brake lines to SS. @JTW and @Kilo427 helped me out! Standard technique and no problems.
SuperDutyJohn
SuperDutyJohn
254
437
Vero Beach, FL
That's the way I did it and I still have air. Will do it again.
Reactions: JTW
If the mc is full then your brake man is letting off the brake or not closing the bleeder quick enough or you’re just not pumping enough.. maybe you don’t have a line tight? Just shooting out things to double check
