P1000 How much lift from fox shocks
Hondoman
Hondoman
727
1,697
Texas
How much lift can be had from fox shocks, if any?
I'm contemplating adding a set and removing the highlifter lift, then adding 30" tires. If I can add 1-1.5" on the foxes I'd be back to the height i'm at now (hopefully not at the expense of ride quality).
Reactions: Ragnar406 and sharp
Ragnar406
Ragnar406
The Great Bald One
4,446
17,026
Bella Vista, AR
What @ohanacreek said . Depending on the tire you can get some 30” tires that measure short that may only rub at the most esteem angles and compressions (with aftermarket A Arms)
If you are going to go with 30’s you will need forward A arms and likely rear A arms. As that is where you will have clearance issues.
A arms are needed with 30’s
The preload is to set correct ride height for varying setups of different machines. You might get a little bit and depending on how heavy your machine is you might have the desired height just by setting the correct ride height.
Hondoman
Hondoman
727
1,697
Texas
Not really the intended use for preload adjustment you want to have about half the shock shaft showing when it’s settled.
Thanks. I understand you can get some lift with the 814s but I'm not sure I want to grind on my a arms to make them fit.
Hondoman
Hondoman
727
1,697
Texas
Forgot to mention, I have satv front a arms.
Hondoman
Hondoman
727
1,697
Texas
I have the front satv a arms installed now. I think if I can get 1" from the foxes I'd be happy.
Hondoman
Hondoman
727
1,697
Texas
What are you trying to accomplish and why ?
The ride quality sux with factory shocks, and the bracket lift made it worse.
I need to run a mud tire in the winter because my tensors do not clean out very well. I hunt in an area with alot of clay in a river bottom. Traction can be a problem crossing creeks etc...
I'd like to go to a 30" tire for looks mainly. 28s look a little short.
In addition, it would be nice to keep the clearance I have now.
Getting rid of the lift is going to make a huge difference in ride quality going with the 30s and aftermarket shocks will give you the clearance you need you can probably get an inch or less of lift out of the shocks but it’s not the way they are supposed to be set up.
I would bet that just setting the preload for the shops and the weight you have will give you the clearance you want
Hondoman
Hondoman
727
1,697
Texas
Thanks, that's what I'm hoping for.
113,740
I have SATV arms and Fox shocks with some pre load and 30” tires. I’d look into getting the rear SATV arms for those 30”s or when you bounce you will rub. Like @ohanacreek said once you get the shocks and pre load them for your weight and set up with the arms you will be happy and will most likely have the set that you desire.
Hondoman
Hondoman
727
1,697
Texas
I wish I had purchased the rear arms when I got the fronts. I got them just before the price hike for $300.
Reactions: Remington
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I am not confident you will get the lift you want and maintain a quality ride or a ride improved from what you have. I tried essentially the same thing you are doing and it rode terrible with pre load cranked down to achieve lift.
Hondoman
Hondoman
727
1,697
Texas
All depends on the tire size... my 30’s I cannot run without the HL lift...
I am looking at outback max's, they are true to size. Looks like I'll have to leave the lift and add better shocks.
208,722
Between my tires, the foxes and spacers.. mine isn’t too bad even with the lift.
When I ordered my shocks, they wanted to know tire size and all the accessories, to send me the right shocks and springs.
9755BC33 F34B 431C 8AD4 CE5613E61F11
