P1000 How to change the air filter on a Honda Pioneer 1000 - Superatv
Russ989
Russ989
22,558
146,452
Not sure I understand the need to remove the rear seat bottoms.
Otherwise nice video.
I thought the same thing, it makes no sense!
Haldog77
Haldog77
NTC's Mafia Enforcer
30,671
282,800
Bossier City, Louisiana
I changed my $44.00 air filter today. The two gaskets that came with it kicked my tail end. I ended up using a dab of 3-M adhesive and some steel spring clips to hold while drying. The smaller o-ring for the filter itself, caused the filter to kick up on the end away from the screw. I think the cover will hold it in place. I know there is bound to be a better price on an air filter.
Reactions: BigOL3
BigOL3
BigOL3
2,994
8,918
$37.xx at RM
Reactions: Haldog77
Haldog77
Haldog77
30,671
282,800
If that filter is dirty, I should start buying used filters from Superatv because mine have never looked that nice
I agree.
DEA78630 605A 4DAF 8533 23277EA1D8D1
56,497
If you do the under hood snorkel and use a pre-filter, they last a really long time. I am snorkeled through the hood with an oiled pre-filter and my filter looked great after 3 dusty days at RRB. This is mine after 875 miles
IMG 20200115 173953
IMG 20200223 123408
Haldog77
Haldog77
30,671
282,800
Reactions: BigOL3
56,497
That's fantastic. I may have to snorkel mine.
I run a Filter Wears cover over an oiled Spectre filter. I know not everyone likes the through the hood snorkel, but it does what it needs to with very minimal effort. If you do the under hood snorkel, I think there's some stuff called Frog skin you can stretch over the opening that acts like a filter. Or you may be able to find an actual oil-based filter that will fit under the hood.
Reactions: Haldog77
