Do you have to have a programmer/tech computer to lower the idle speed on the Talon's? I really think if I lower the idle speed the transmission will be more apt to mesh into low gear better.
If the idle speed is fast enough to be dragging engagement, then you would get gear clash when moving the shifter. That is not the symptom I have seen described.
