P1000 Ignition Switch wiring diagram
F
FlagHonda
Flagstaff
Can anyone give me the color codes for the wires coming from the ignition switch on a Pioneer 1000-5? I would like to wire in a toggle switch to turn things on and a push button for the starter. That way I can start it when I forget the key! I see the connector behind the battery area, so that is where I would like to tap into. Thanks for the help.
Reactions: BWAF
67,170
Yes, and No.
Not recommended you tap the IGN wire for "key on power". You should tap that 15amp acc fuse/CIG acc plug wire for this. that way its protected by the fuse in case something goes wrong. Not saying it want work, just I wouldn't do it.
Standby for info on the ign wire diagram.
Reactions: BWAF
67,170
Upload 2018 8 18 23 16 59
Reactions: JTW and BWAF
67,170
I spent sometime looking for a push button proximity key system. No luck without all the other bells and whistles I didn't need.
It would be cool to have one...
