I have a 2017 P500. As we all know, when revising the suspension for the 2017-19 P5, Honda installed softer springs and, i think, shorter shocks. The result was a loss of ground clearance from 9.6 inches to 8.5 The trails that i run in are mostly abandoned, overgrown logging roads that look more like stream beds than trails. Basketball size boulders are the norm. I regularly bottom out or get high centered.
I am planning on installing 26 inch BH 2.0s that should get me back to around 9.5 inches. I am also considering a small lift kit that claims a 1.5 inch lift. This kit has s.s. bolt-on brackets that relocate the upper shock mounts a bit lower to give the lift. i would also add 1.5 inch spacers on the stock wheels. This should give me around 11 inches of clearance.
Has anyone used this type of lift kit before? Does this setup sound reasonable?
