Superthrill
For those of you that had to replace the injector harness, what symptoms did you have? Would it run rough all the tie or come and go? Mine died in Tackett 3 different times. Restarted each time. Had to ride black top back to the truck and I noticed it would occasionaly run weird at part throttle, part load. Not really a miss. Then it would die. Have to pull over and it would restart. Did not think about letting the key stay on long enough to see a code.
Hoping to pull it apart and check the harness this weekend.
