P1000m5 Interior light
T
taylorman
167
97
Lafayette La
Looking for interior light options. Go.
If you want just a single color, these are awesome. They are super bright though. I put a dimmer on mine. I have one in the front and one in the back.
97aaac2f83de2ce0adf65407c65a28b1
They are waterproof also
Here's a pic of them on.
78e119112fe10f67f675347b243a7a5b
Again, that's just two of those!
Here's the dimmer in the dash....
1d146645ccf6c7ece32c5284874ecae1
T
taylorman
167
97
Lafayette La
How are those applied? Are they stick on?
They are stick on. I tried putting them on the roof and the sun would release the adhesive. Now I have them on the rollbar.
I've had 4 on the back bumper of my truck for about a year now and they've never come off. They are wired into the back of trailer light plug so they come on automatically while in reverse. I've had great luck with them, they've been reliable and they're cheap.
Reactions: CumminsPusher
Delton
Delton
Honda Fanboy
9,967
31,487
Middle TN
You will like them. I stole idea from Joey as well. As he said...very very bright. Lose a contact lenses in the floorboard?? No problem lol. Mine are stick to rollbar as well plus couple of cable ties.
Reactions: joeymt33
322,689
I concur also with Joey. These are the same ones I've been using and they are very bright. The metal housing on mine wrapped around the back of the lights and the double back tape sat over the tabs funny so I cut the tape under the tabs and put a new layer of good automotive 3m doubleback over the top. It makes it smoother so it sticks a lot better.
Sent from iPhone
Reactions: joeymt33
T
taylorman
167
97
Lafayette La
Holy crap these are bright. So do these need a fuse? Where do you guys ground small items like this that go straight though the switch with no relay? Straight to battery I assume.
Mine run thru the cooper PDM so they are fuse protected. I really can't remember where I grounded them but their very low amp draw and could probably be grounded anywhere you like.
113,743
Those are bad a##! Getting some for myself! Will be great when getting my bow and gear out in the morning before heading to my tree stand. Nice!
Delton
Delton
Honda Fanboy
9,967
31,487
Middle TN
i zip tied a headlamp to the roll bar and it works great and was very inexpensive.
As long as you can see with it. Thats all that really matters right?
T
taylorman
167
97
Lafayette La
What size fuse should I use with this light?
AKRider
AKRider
1,402
3,224
Palmer, Alaska
I use a 2A. I can't find a 1A... lol. They only pull an amp. Here's a good online calculator to keep handy on your phone.
Watts to amps (A) conversion calculator
There's also apps you can put on your phone. I just downloaded a simple one called Ohm's Law Calculator.
