is there a preload for the shocks
Hondoman
Hondoman
727
1,697
Texas
Hello my name is Nibsy , ive just bought a talon x, I find the ride real rough comparison to my rzr xp, is there a way of adjusting the spring pre load to soften the ride.
Welcome.
Have you checked the air pressure in your tires? Too much can make for a harsh ride.
Reactions: Isaiah and BWAF
5,492
25,267
Hi Nibsy, welcome to the site.
I'm new to SxSx but have a Talon R. The X rides stiffer than the R, there are aftermarket springs available if lightening the preload doesn't help enough. Since this might not be seen by many in the Intro section, I'll tag @TerryH since I know he's modded his X suspension a bit.
Todd627
Todd627
56,734
619,430
MI
Welcome from The Great Lakes State 😎
Remember....pics or it didn’t happen 😉
#NTC
TerryH
TerryH
664
2,241
Springdale, Ar
The X needs aftermarket tender springs. You'll gain nothing by raising the preload adjusters other than lowering the ride height. Honda/Fox has not done us any favors with the spring selection. The main springs are not too bad but the tenders are useless, especially on the back. Bandit UTV Suspensions has got a great handle on what needs to be done. Their tender springs will definitely soften the ride. Unfortunately they are closed for a couple more weeks because of the virus. Here's the link to the springs on their site. Best $200 you can spend on an X. I'll link my videos on the subject also.
Reactions: CID
208,729
WELCOME from NW Arkansas!
T
ttalley63
Arkansas
Anyone know if the preload for an x4 with bandit tender springs is the same as the x 2 seat. My bandit tender kit didn’t come with recommended preload for x4 and I have not been able to find anything out.
Reactions: TerryH
5,492
25,267
Terry covers that in the two videos above - 5" front, 4" rear (exposed threads from the base of the shock head to the top of lock ring).
TerryH
TerryH
664
2,241
Springdale, Ar
I show the process that everyone should be doing to set their shocks in the full spring kit video. This procedure tailors the preload to your particular configuration.
T
ttalley63
Arkansas
Thanks for info. All the info and videos I’ve seen have been on the 2 seater didn’t know if anyone with the x4 knew of the same preload worked or if they had one that they used that worked good.
TerryH
TerryH
664
2,241
Springdale, Ar
You will really be way ahead to go thru that process form the video. Super easy and doing that will get you just right for your exact weight.
